Members Yvon Posted 6 hours ago Members Report Posted 6 hours ago Hi, I have a Pfaff 145, that I’m trying to reduce the clearance between the hook and the needle. Timing is ok, but the hook is too far away from the needle. when I move the shuttle block towards the needle, it hits the hook washer, while the clearance is about .005”. has anyone encountered this situation before, and what is the solution? Thank you Quote
Northmount Posted 4 hours ago Report Posted 4 hours ago 1 hour ago, Yvon said: I have a Pfaff 145 Moved your post to Leather Sewing Machines Quote
Contributing Member friquant Posted 12 minutes ago Contributing Member Report Posted 12 minutes ago 6 hours ago, Yvon said: when I move the shuttle block towards the needle, it hits the hook washer I'm not sure what you mean by hits the hook washer. Perhaps you can include some close-up photographs? On my Jianglong 341 I had to slide the feed eccentric farther down the hook driving shaft before I could move the hook close enough to touch the needle. Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
