Members outaluck Posted November 14 Members Report Posted November 14 Would this work with singer 11w154 to replace the old motor? Quote
Members Constabulary Posted November 14 Members Report Posted November 14 it will but depends on your expectations regarding sewing speed. You may need a smaller pulley or speed reducer in addition. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members outaluck Posted November 14 Author Members Report Posted November 14 Dam lol looking to slow it down Quote
Members dikman Posted November 14 Members Report Posted November 14 Best way is to fit a speed reducer pulley as well. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
AlZilla Posted November 14 Report Posted November 14 2 hours ago, outaluck said: Would this work with singer 11w154 to replace the old motor? It will But you may want to find a version where the control box is separate from the motor. This way the controls can be mounted at the edge of the table where you can play with them. The style you show would require you to climb under the table to tweak any of the settings. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
kgg Posted November 14 Report Posted November 14 13 hours ago, outaluck said: Would this work with singer 11w154 to replace the old motor? Yes and No. My two cents: i) Looks like the cooling fan is incorporated in the motor pulley. So getting a smaller motor pulley with the cooling fans maybe limited. ii) Appears to be a 550 watt 6 coil brushless servo motor which would probably work. A 12 coil 550 watt would be better but would cost more (2X). iii) The start up speed could be as high as 500rpm which will give you startup jerk. A speed reducer would help eliminate that or go with a brushed servo motor rather then the brushless servo motor. iv) Make sure the operating manual comes with the setup. v) Like @AlZilla has mentioned the control box is going to be in a awful location under the table so you are going to be down on your hands and knees to change the settings. kgg Quote Juki DNU - 1541S, Juki DU - 1181N, Singer 29K - 71(1949), Chinese Patcher (Tinkers Delight), Warlock TSC-441, Techsew 2750 Pro, Consew DCS-S4 Skiver
Contributing Member friquant Posted November 14 Contributing Member Report Posted November 14 15 hours ago, outaluck said: Would this work with singer 11w154 to replace the old motor? Plug this one into the wall, and see how fast the pulley moves at its slowest setting. You can put a piece of tape on the pulley so you can count revolutions as you time it with a stopwatch. That will inform the slowness this one is capable of. By the way, how fast is your old motor? Quote friquant. Like a frequent, piquant flyer. Check out my blog: Choosing a Motor for your Industrial Sewing Machine
AlZilla Posted November 14 Report Posted November 14 It takes some research but you can find cheap servos with a start speed of 100 rpms. In my case, with the small pulley and a speed reducer, I can get down to 11 stitches/minute. There's a whole rabbit trail of slow speed versus cooling. But I think at the hobby level we're not running these things for prolonged periods of time, so it's probably not a giant issue. 11 spm is ridiculously slow. Quote “Those who can make you believe absurdities can make you commit atrocities.” - Voltaire “Republics decline into democracies and democracies degenerate into despotisms.” - Aristotle
