Members charlesfenley Posted November 15, 2025 Members Report Posted November 15, 2025 I have a lot of leather scraps from using leather dies to cut out leather shapes. I want to know the best way to turn those scraps into leather dust for embossing projects. I use a sharp chisel to cut the leather into small pieces about 1/8 inch in size. I used a vita mix mixer and it broke the mixer, then I used a food processor and all that did was make the leather pieces fuzzy. I want to try an electric grain mill next but that can be pricey. Is there a better way to accomplish this task? Quote
CFM chuck123wapati Posted November 15, 2025 CFM Report Posted November 15, 2025 3 minutes ago, charlesfenley said: I have a lot of leather scraps from using leather dies to cut out leather shapes. I want to know the best way to turn those scraps into leather dust for embossing projects. I use a sharp chisel to cut the leather into small pieces about 1/8 inch in size. I used a vita mix mixer and it broke the mixer, then I used a food processor and all that did was make the leather pieces fuzzy. I want to try an electric grain mill next but that can be pricey. Is there a better way to accomplish this task? a belt sander would be my choice 80 grit or so. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members dikman Posted November 15, 2025 Members Report Posted November 15, 2025 Soak your little pieces in water (hot water?) to soften them - might need a few days - then try a blender. Hopefully it will turn them into mush and then dry it out? No idea if it will work. Quote Machines wot I have - Singer 51W59; Singer 331K4; Seiko STH-8BLD; Pfaff 335; CB4500. Chinese shoe patcher; Singer 201K (old hand crank)
Members Handstitched Posted November 16, 2025 Members Report Posted November 16, 2025 I am intrigued 🤔. This is something I have never heard of. So,the pieces are too small to make into other small saleable items ? Like using wood dust or wood particles i guess .So you use a binder like in particle board or chip board? HS Quote ' I have a very gweat friend in Wome called Biggus Dickus, He has a wife you know, do you know whats she's called? Incontinentia.......Incontinentia Buttocks '
Members BlackDragon Posted November 16, 2025 Members Report Posted November 16, 2025 57 minutes ago, Handstitched said: I am intrigued 🤔. This is something I have never heard of. So,the pieces are too small to make into other small saleable items ? Like using wood dust or wood particles i guess .So you use a binder like in particle board or chip board? HS I've seen leather dust mixed with cement to make a filler or packing for the back of 3D carvings. Quote
Moderator bruce johnson Posted November 16, 2025 Moderator Report Posted November 16, 2025 Coffee grinder jumped to mind when I read this. I remember some posts from the early days here. As I recall - "old coffee grinder" or "cheap coffee grinder" were the key recommendations. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members charlesfenley Posted November 17, 2025 Author Members Report Posted November 17, 2025 I have an old coffee grinder that hangs on a wall I will try that; they are like a grain mill but smaller. belt sander sounds good, but I will need to figure out a V- trough to hold the leather pieces and to press them into the sander. Leather dust is mixed with rubber cement and used to help create a 3D affect to a leather item like a picture. It is called embossing or extreme embossing. Quote
CFM chuck123wapati Posted November 17, 2025 CFM Report Posted November 17, 2025 16 minutes ago, charlesfenley said: I have an old coffee grinder that hangs on a wall I will try that; they are like a grain mill but smaller. belt sander sounds good, but I will need to figure out a V- trough to hold the leather pieces and to press them into the sander. Leather dust is mixed with rubber cement and used to help create a 3D affect to a leather item like a picture. It is called embossing or extreme embossing. The art of Embossing by Al Stohlman shows how they use plugs slightly sculpted or tooled, wouldn't that be much easier than all of this ? Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
Members BlackDragon Posted November 17, 2025 Members Report Posted November 17, 2025 2 hours ago, chuck123wapati said: The art of Embossing by Al Stohlman shows how they use plugs slightly sculpted or tooled, wouldn't that be much easier than all of this ? The leather paste conforms better to the shape of the embossing. Quote
CFM chuck123wapati Posted November 17, 2025 CFM Report Posted November 17, 2025 1 hour ago, BlackDragon said: The leather paste conforms better to the shape of the embossing. if that's the best it does, it's nowhere near better. Quote Worked in a prison for 30 years if I aint shiny every time I comment its no big deal, I just don't wave pompoms. “I won’t be wronged, I won’t be insulted, and I won’t be laid a hand on. I don’t do these things to other people, and I require the same from them.” THE DUKE!
