How does this "tilt stump" attach to the table? Is there a nut under the table? Or do I pry the plastic cap off to reveal a bolt head and it screws out the top?
This is a customer's machine, a FEIT DCL-8500N. The closest manual I have found so far is this one for the Artisan 8500N.
I brought the head unit home with me for repair. But I'm convinced that the tilt stump is in the wrong place. It prevented the head unit from tilting all the way back. But after a couple minutes, the handwheel end of the head unit slithered off the table hinge and into the drip pan. Nobody was hurt in the process, but seems liable to happen again.
My intention is to move the stump further away from the operator, and a maybe a couple inches left (from the operator's perspective) so that it loses its tendency to lift the machine off of the table hinge closest to the hand wheel. But I'll need to pack the appropriate tools to do so, and while I was there I did not manage to figure out how it attaches.
artisan-8500n__similar-to-feit-dcl-8500n__manual.pdf
friquant. Like a frequent, piquant flyer.
Check out my blog: Choosing a Motor for your Industrial Sewing Machine
This a typical location for the "tilt stump". Typically just made of plastic, pressure fitted into a hole drilled into the table top and meant as a temporary rest. The machine " slithered off the table hinge and into the drip pan " indicates to me incorrect / damaged hinge and or hinge installation. I have never had a head slip off and with my stubby fingers I am also titling my flatbed machines back to install / remove bobbins.
kgg
Edited by kgg
