Members ThisIsMyFirstRodeo Posted 5 hours ago Members Report Posted 5 hours ago Ok, so I’ve noticed that a lot of people recommend sanding your edges down, presumably for a cleaner, more professional look. But most people seem either to not sand, or they don’t mention it. I’m thinking there has to be an obvious difference between the two, but does anyone have a side-by-side pic or such to point it out to me? I have experimented, but I’m not sure what I’m really looking for… May you never burn your bacon, AZR Quote
Members TomE Posted 2 hours ago Members Report Posted 2 hours ago Reasons to sand edges include leveling multiple layers, removing excess glue before finishing the edge, and smoothing the fibers as part of the burnishing process. What are you trying to achieve? I routinely sand to level an edge or remove glue, and I avoid it when burnishing. If my regular burnishing methods don't produce a smooth enough edge then I'll sand and do more burnishing. Depends on the tannage, moisture content, the part of the hide I'm working with, thickness, etc. Quote
Members ThisIsMyFirstRodeo Posted 1 hour ago Author Members Report Posted 1 hour ago At this particular project, I guess the sanding is to level 2 layers for burnishing? I did get a pretty decent burnish with it, but I don’t know if that’s from sanding the edges or because I’m finally becoming more competent. Anyway, thank you for the various reasons to sand. When you do sand, is there a particular series of grits that you use? I feel like there’s a limit to how finely you can sand an edge before it’s pointless. I definitely saw results with up to 600g, but I don’t think I saw anything whatsoever with 800g/1000g. Quote
