The tandy by me carries black, I think there is three sizes, I bought the midsize, and use a small machinist vice to hold the pieces if I need to use a small file on them to shorten them for thinner applications. The metal is quite soft so filing is pretty quick and as long as I keep the angles true there is no adverse effects when scewing them together.
  • Replies 21
  • Created
  • Last Reply
Top Posters In This Topic
Thanks Jordan. I bought 1/2" and 3/8" versions yesterday online and will try them out once I get them. The 1/2" may be too long but I can always use them for mag carrier applications. Now to hunt down some rubber washers of the right size... :)
  • Ambassador
PETERK.......CHECK OUT THE "FAUCET WASHERS" IN THE PLUMMING DEPT.
SOME ARE BEVELED AND THERE ARE OTHERS THAT OR FLAT............
Luke
Thank you much! I'll check it out today.
As you finish, . . . everything else done, . . . wrap the threads with two wraps of teflon tape. It will prevent the screws backing out because of the pressure of the washer.
May God bless,
Dwight
www.dwightsgunleather.com
Any idea where to find this part?
Mainly for aesthetics...
Edited by Peterk
I have seen them at auto parts stores for interior trim attachments and also at hardware stores. There are some specialty stores around that sell all kinds of nuts bolts and fasteners That type of finish washer is also used in the boating industry a lot.
Hardware store. Sometimes they are called "cup washers", or at least that what folks in these parts call them.....
Mike DeLoach
Finish washers Lowes or Home Depot.
