Marlon, you're right about the dremel. This is why, if you're going to use one, it needs to be in a dremel drill press or in some sort of jig that keeps the the drill bit (&, of course, the holes, by extension,) straight & aligned.
russ
Gee, is that why the stitching holes I make with a cordless drill are all over the place????? :head_hurts_kr:
Mike DeLoach
  • Replies 29
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
Here's how I do mine. Instead of drilling, I sharpen the shank end of the drill bit and punch it while the press is running. The hole is much cleaner and it burnishes the hole.After stitching the holes will close up on the thread much better.I also made a seperate table(covered with UHMW for easy sliding) for my drill press and use notched boards ( for the belt loop on sheaths) to keep the leather flat. Works great for me and its fast.Dave
You're giving away the secrets. Why not put a nice sharp and stropped awl blade in the drill press, set it at the correct angle to the stitch line and end up with nice holes that look like they were hand punched with an awl? SSShhhhhhhhh.... don't give up the secrets ....
Rayban,
Nice sheath man! I love it. Suits the knife well too.
I think we should use what works for us, and if that works - cool! I've tried multiprong punches, diamond awl, etc. and unless it's going straight up & down, it looks bad on the back with all of them. I wonder if I can adapt the stamping press thingy to hold the punch somehow. A talented engineer like me (snicker) should be able to figure something out! No drill press available or I'd be all over that! :no:
Anyway my question of the day for you is... (drumroll please) Do you have trouble with the stitches wanting to pull through the leather? I've got a practice piece and with an Osborn D0249 (a 5 prong punch), it doesn't take much pull at all to cut right through the leather. A similar tool with a slightly wider spacing didn't seem to have the tendancy to cut so deep and easy.
This could VERY well be old dried out leather and that's the problem; but I figured I'd ask since you have fairly dense stitching and small thread, and beautiful results. Could it be machine vs hand?
Thanks,
Brent
Brent Howard
CALG, HLG
Has anyone thought to chuck an awl blade in the drill press and use scrap leather on the bottom. (Don't turn the drill on of course) but this way you could get straight holes.
Just an idea. :dunno:
Hey Bill I just read your post. How great minds think alike. :crazy:
Edited by Rawhide
Marlon
The only problem I can see using the drill press with the awl is keeping it aligned because the chuck would rotate too easily. I think a modified arbor press might work better. They can be had pretty cheap and the mods aren't that difficult.Dave
here's one I modified for my makers stamp
On my sheaths i chuck up a awl or somtimes a needle in press and do the FRONT side and welt of the sheath then glue it and use hand awl to find the back side. If i use the needle i turn the press on it seems to burnish the hole a bit if i use awl i just press through. Anyway thats how i keep the holes straight.
Romey
Cowboy inc
highcountryknives
let me see the back of it......that will tell the tale.........
I had to deliver the sheath before I could take the picture of it's back-side. Guess, you'll have to take my word for it...it looked pretty much like the front.
Again, going through 6 layers of leather, the drill press beats the heck out of the awl, in my opinion.
AND....the customer loved it, and has ordered another one.
Rayban
www.rgleather.net
Rayban,
Thanks,
Brent
Brent, the thread pulling thru has not been a problem with my hand-stitching. I wonder if you have a machine tension thingy issue?? I supposs I could use a #5 instead of a #6 wheel in those really thick 6 layer areas....
BTW, I mostly use artificial sinew with the sheaths I make.
Thanks for your kind, and understanding words.
R
P.S. I found my table top model drill press in Craig's List for $30.
Rayban
www.rgleather.net
