Members Billy H Posted November 19, 2010 Members Report Posted November 19, 2010 Saddlebag, Great idea! Hidepounder, I know that you were kidding; but that is the absolute truth! The last saddle I built had blood stains all over the underside of the seat jockey. I was truly in a panic, thinking that I would not be able to get the leathers fished through. My right hand knuckles were sore for nearly a month. Quote
Members GrampaJoel Posted November 19, 2010 Members Report Posted November 19, 2010 Now this I would like to see a photo or two of. This sounds like a knuckle saver for sure. Quote
Members mulefool Posted November 19, 2010 Members Report Posted November 19, 2010 I've used a flexible plastic ruler in the same way, but they're a little more brittle, i've broken a couple that way. This sounds like it would be less likely to break. I guess frustration is the mother of invention. thanks for sharing. Chris Quote www.horseandmulegear.com
Members alb Posted November 21, 2010 Members Report Posted November 21, 2010 I have scraped knuckles right now from a particularly ornery saddle I worked on last week. It's not often that the huge wooden wedge we use fails, but we sure worked up a sweat on this one. I'm looking forward to trying this trick on the next tight one. Thanks for posting! Ann I've used a flexible plastic ruler in the same way, but they're a little more brittle, i've broken a couple that way. This sounds like it would be less likely to break. I guess frustration is the mother of invention. thanks for sharing. Chris Quote
Members Saddlebag Posted December 20, 2010 Author Members Report Posted December 20, 2010 I'm glad this trick is of benefit to others. While I was trying to figure out a better/easier way to string leathers I knew I needed something slippery, like plastic. Lo and behold an empty tall yogurt container was sitting on the counter staring at me. I had a huge AHA moment and cut a strip of plastic from it. Scrounged around and found another. The curl in the plastic is also helpful and for any yogurt lover, replacements are cheap. Quote
Hennessy Posted December 26, 2010 Report Posted December 26, 2010 when i replace leathers i first tie curtain cord onto old leathers and slide them out leaving the cord on both sides of the bar, right and left has cords.with these cords i tie thru a hole on the tip of new leas i use skidmores a buttery paste and grease up leas about one foot then pull corded tip up n over n under rarely a problem sometimes th handhold skirt nail needs to be loosed works good for me. Quote
Members Saddlebag Posted January 9, 2011 Author Members Report Posted January 9, 2011 Hey guys, had another AHA moment today. While trying to deal with a bad case of bronchitis for the past few days my horse's water buckets froze solid. I don't normally let this happen but if I bend over I start marathon coughing bouts. While leaving the house I noticed the plastic tobaggan which has sides, leaning up against the railing. This is where the AHA hit me. At the fence I slid it backwards partway under the fence with my foot, moved the pipe from the hydrant and voila, a new water container. Any leftover was easily emptied without my having to bend over. The tobaggan is now outside the fence waiting for the next watering. Quote
Suze Posted January 9, 2011 Report Posted January 9, 2011 See there is always a "second use" for everything you just have to think of it first feel better soon Quote Reality is for people who lack imagination Whether you think you can or think you can't - you are right. ~Henry Ford
Members buckaroogal Posted January 11, 2011 Members Report Posted January 11, 2011 I take a coat hanger run it up thru first then with the end bent put that thru the bottom hole of the leather and pull it thru. Quote
Members Randy Cornelius Posted January 12, 2011 Members Report Posted January 12, 2011 I may have to try this one, But I keep a bale of big bailer twine in the shop. Tie one end to the old leather when I pull them out. Leave the twine hanging out and punch a small hole in the end of the new leathers, tie on the twine, soak the end of the leathers to bend them just a little and usually they pull right through without sikined knuckles. I read in the Al Stolhman books that he used Vasline to lube up the bars for pulled the leathers through. I have some saddle butter of some flavor that I have used but don't like the idea of Vasline. Randy Quote Randy Cornelius Cornelius Saddlery LaCygne, Kansas Randy & Riley Cornelius Ride Hard, Shoot Fast and Always Tell the Truth...
