Contributing Member UKRay Posted May 22, 2009 Contributing Member Report Posted May 22, 2009 I have been thinking about adding some kind of power sander to my workshop and wondered what you folks think is the most effective type? I have looked at belt sanders, drum sanders and disk sanders and can see good reasons to use all of them but only have the space for one - which would you suggest and why? How do you get the best from your sander? Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Ambassador pete Posted May 22, 2009 Ambassador Report Posted May 22, 2009 I have been thinking about adding some kind of power sander to my workshop and wondered what you folks think is the most effective type? I have looked at belt sanders, drum sanders and disk sanders and can see good reasons to use all of them but only have the space for one - which would you suggest and why? How do you get the best from your sander?Ray A dremel tool and the little barrel sander that it comes with works great for all sizes of projects. Quote
hidepounder Posted May 22, 2009 Report Posted May 22, 2009 Ray, I use a belt sander more than anything else. For small curved edges I use the little drum sanders. I have a series of different sizes that I use on the end of my burnisher or I put them in a dremel. But 99% of my sanding is done on the belt. Quote
Moderator bruce johnson Posted May 22, 2009 Moderator Report Posted May 22, 2009 Ray, I wouldn't be without two - benchtop and Dremel. I like the benchtop belt sander with a 4x36 belt. I have it mounted backwards so the free part of the belt extends over the front of my bench. I can get down into the inside curves that way. It is pretty forgiving on trueing up edges and mild shaping. Because it is a lower speed and the belt is moving more, it doesn't heat up and scorch like a Dremel will. The top is good for trueing up flat edges like a the edges of my frames. I use the Dremel some too for tighter areas. You just have to be careful to use a light touch and keep it moving to prevent scorching. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members badger Posted May 22, 2009 Members Report Posted May 22, 2009 Ray, You should have spotted mine in the workroom when you visited (good to see you!). Having said that, it was behind you and we were in the room at the same.........you may have noticed that there isn't room to turn around with two in there In case you didn't see it; 4 inch by 36 inch belt in the horizontal position, dust extracted. Badger Quote
Ambassador Luke Hatley Posted May 22, 2009 Ambassador Report Posted May 22, 2009 Ray mine is a belt sander from Harbor Freight, you should be able to find a 4x36" belt sander in the U K. there is a lot of different grites of belts avaiable for it.the belts are very easy & fast to change. Quote Luke
electrathon Posted May 22, 2009 Report Posted May 22, 2009 dust extracted. Nothing about working with leather bugs me... Except the breathing and smell of the leather dust. It just seems icky. Aaron Quote
Bree Posted May 22, 2009 Report Posted May 22, 2009 I use a spindle and belt sander combo http://leatherworker.net/forum/index.php?s...ost&p=93084 Works great. Quote Ride Safe! Bree 2003 Dyna Wide Glide Memberships: Iron Butt Association, Niagara Falls HOG, Wild Fire HOG NRA, Niagara County Sportsman's Association
Moderator Art Posted May 22, 2009 Moderator Report Posted May 22, 2009 Hi Ray, This is way overkill because of the knifemaking thing, but a Burr King, and a Bader 2x72, both killer belt grinders and a lot of accessories, then there is the old Craftsman 6x48, none are terribly variable speed (you have to change pulleys). I been wanting to replace the motors with three phase and put a VFD on them which would be better for leatherwork. Then I have one of those oscillating jobs that I stack everything on, add to that a couple of Baldor buffers and a drill press that I can chuck a sanding drum into. I haven't had the opportunity to use the surface grinder on a piece of leather yet, magnetic chuck might be kinda useless. One of those knifemaker's buffers from Grizzly might be good (kind of like that Weaver thing on steroids), but I don't have one........where is that catalog? The mill and lathes are worthless for leather, but you can make parts for weird or old sewing machines and are just handy to have. But I digress...... That old Craftsman 6x48 seems to go and go, the only optional thing on it is a foot pedal for on/off, and it has one of them disk sanders on the side (seldom used), good sander/grinder and cheap. The Bader has an attachment with a 3/8" wheel for tight places on holsters, but it spins it fast, I have to use Militec on it to keep from toasting the bearings. So the answer is: Used 6x48 (Powermatic is someone doesn't know what he has) and a Dremel or Foredom. Art I have been thinking about adding some kind of power sander to my workshop and wondered what you folks think is the most effective type? I have looked at belt sanders, drum sanders and disk sanders and can see good reasons to use all of them but only have the space for one - which would you suggest and why? How do you get the best from your sander?Ray Quote For heaven's sakes pilgrim, make yourself a strop!
Members celticleather Posted May 22, 2009 Members Report Posted May 22, 2009 Ray I spotted this (http://www.maplin.co.uk/Module.aspx?ModuleNo=43273) in our local Maplin store at the weekend. I wonder if it would do the same job as a Dremel, but at a much lower cost - £24.99. Terry Quote When everyone is somebody, then no one's anybody
