Does anyone make pre-cut, veg tan oval shapes?
I'm looking for an oval shape around 110 or 120mm measured on the long axis.
I know it's a long shot and I'll probably need to have a press knife/tool made.
Cheers,
Badger
Edited by badger
Why not do up a quick oval in Corel Draw or Adobe Illustrator, print, trace to poster board or card stock pattern. I'll do one up for you later today,if you wish. How high would you like the oval to be?
ed
Cheers,
Badger
I remember Tandy selling ovals years ago- have you checked their catalog? They have lots of pre-cut shapes available. If you are going to need so many that buying a hide and and a die is more economical, there are a couple of companies that make dies listed on the Suppliers page. Cheap alternative- get a cookie cutter (or other template) and press or trace the shape, then trim with Super Shears.
Johanna
You cannot depend on your eyes when your imagination is out of focus. - Mark Twain
Yup - I've got a knife for that one, Karl. Give me a call.
Cheers,
Badger
"Some mornings, it's just not worth chewing through the leather straps"
Ray Hatley
www.barefootleather.co.uk
Thank you everyone.
Ray, I'll give you a ring.
Love this place..................
Badger
Cheers,
Badger
Were you looking for just the pattern or precut ovals. Here is an oval 120mm wide by 60 mm tall.
ed
120by60mmoval.pdf
120by60mmoval.pdf
You can get a mallet die made for around $50 to $80 to stamp out ovals of this size.
ed
Cheers,
Badger
ed
  • Ambassador
Badger the art supply stores in the U S has plastic Templates that you might can use.
there one that is an" ISOMETRIC ELISPS".HOPEFULY YOU HAVE SOME THERE ALSO.
OR CHECK OUT "DRAFTING SUPPLYS".
But on the other hand Cousin Ray will come thru...
Luke
Job done, Cousin Luke. Those pre-cut oval shapes the Badger wanted are in a mailing bag waiting for the post office to open!
Ray Hatley
Cheers,
Badger
Hi Badger,
I sell precut ovals in several sizes. Largest in stock is about 105mm. But if you need maybe up to a hundred, I'm sure I could have a die made. And if you'd rather have a die made, it's possible that I could handle that for you as well. I think we have access to the least expensive die maker in the country. You can reach me at either 800-668-8518, or kevin@springfieldleather.com
Let me know if I can be of help.
Kevin
