Your help please. I want to make some wallets that have a see through window for the ID. What kind of plastic is it? Where can I buy a couple of sheets? How thick should it be?
Thanks, Steve
Lexan is good because it doesn't scratch easily. I think regular polycarbonates scratch easilt. Any plastics distributor like Cadilac Plastics will have it. If you don't think it needs to be that tough, you can get paper protector in office supply store like Office depot.
God, Family, and Country (although liberals are attempting to destroy these in the USA)
Good afternoon,
We use clear plastic available from Hobby Lobby in the material department. It comes in various thickness and is very pliable and easy to sew. Good luck.
Leathersmithing by Liz
Thanks, Steve
Thanks for the info Regis
Good afternoon,
Liz,
Thanks for the tip. There's not a Hobby Lobby in LA, is there a brand name on the plastic you buy besides Hobby Lobby?
  • 2 weeks later...
Just a stray thought, but I had some leftover clear material I used to make windows in a jeep top I rebuilt - years ago. It sewed up nicely, was crystal clear and very tough - and if you can wrangle up an automotive upholstery show near you, they may have some. Look for it to be over twenty bucks a yard.
Best,
Kate
KATE'S CUSTOM GUNLEATHER
and
KATE'S CUSTOM BRIDLEWORKS
Sultan, WA USA
Steve, you're thinking of the flexible stuff, right, not the rigid plastic? I make luggage tags with see-through windows using clear vinyl plastic sheet you can buy at any fabric store. (Same stuff as Liz mentioned.) WallyWorld also carries it. It's a fairly tough material and you can sew through it.
Kate
The Local ACE Hardware carries acrylic in 8x10 sheets ind various weights...your local one may also.
Jana
"A journey of a thousand miles must begin with a single step." - Chinese Proverb
Thanks for the help everyone. I found some "Dura-lar" online. I go it already and looks really good.
Be sure to let us know how you use it and how it works out for ya. Im looking to do some as well and will need to decide what to use.
