Members dragonspit Posted August 16, 2010 Members Report Posted August 16, 2010 very nice tute. thanks for taking the time. Quote
Members TexasJack Posted August 17, 2010 Members Report Posted August 17, 2010 Nice job on the tutorial! Quote
Members cajunbill Posted August 22, 2010 Members Report Posted August 22, 2010 That was a very useful tutorial, thanks for the pictures and write up. Quote Tougher than a woodpecker beak
Members Miett Posted August 22, 2010 Members Report Posted August 22, 2010 Excellent--Thanks very much for posting! Once I have the experience necessary, I'll definitely try making this pretty little thing! Quote
Members WhiteFalcon Posted August 27, 2010 Members Report Posted August 27, 2010 Good tutorial! I'll just jump in and confirm that these are Le Prevo buckles (0508-20 3/4" brass full roller buckle - £4.73 per 10). They're the same ones that I use on my pouches! Terry Very Nice Job!! Quote
Members Jacko P Posted August 27, 2010 Members Report Posted August 27, 2010 Thank you for posting this tutorial MagiKelly. I too am self taught and was rapt to see that I had worked out some of your techniques for myself. I mold my pouches over this form I came up with The major difference in our techniques being I use multiple rubber bands to hold the leather to the form and them clamp the female piece of the form over the base until dry. Occasionally a stubborn bit of leather requires staples around it's edges outside of where I'll be trimming it to hold curled edges down before I clamp it.<br /><br />Something as obvious as varnishing the timber had not occurred to me. I originally waxed it but have got lazy with this. I'll give my form a sand and lacquer it. I will also give your tacking idea a go as on occasion I have problems with the leather not molding perfectly, particularly around the bottom corners. I intend to make myself up a template to place over the top of my pouches so I can reliably trim them to the same profile. I will also be making a new form as the mood moves me using thick plastic from a cutting board as the base and female part of the form. I may laminate several thickness's together to make the pouches body mold.<br /><br />The longer I spend on this forum, the more I'm liking it - thanks again<br /><br />regards Jacko Quote To my deep mortification my father once said to me, You care for nothing but shooting, dogs and rat catching, you will be a disgrace to yourself and all your family." - Charles Darwin
Members SelfTaught123 Posted August 29, 2010 Members Report Posted August 29, 2010 Thank you for your wonderful step by step on this pouch and process, I have been starting teaching self the wet shaped leather work field, planning on doing masks for my friends and my self, however, this pouch has given me an idea for a Double Cased Item, a spherical purse, about five inches diameter. Do you have any sugestions on doing a double shaped item, rather than an item that is shaped on one side, and flat form on the other? Quote
Members MagiKelly Posted August 30, 2010 Author Members Report Posted August 30, 2010 I have never done a double shaped item so have no experience to pass on. If I were to try it I guess I would mould both sides on the same form to make sure they matched up exactly. I'll be looking forward to your tutorial when you try it Quote
Members Dolphini Posted September 17, 2010 Members Report Posted September 17, 2010 Wow! Great tutorial, beautifully displayed and explained. Thank you. Quote
Members almac Posted December 27, 2010 Members Report Posted December 27, 2010 this is probably one of the best wet forming tutorials that i have seen! thank you so much for your time on this. one question tho. if you were going to basketweave stamp the pouch, would you stamp it on a flat surface and then mold it or mold it and use the face of the mold to stamp the leather before it dried? thanks again. al Quote
