dscott
couple of wallet/card holders
been trying to learn to hand stitch made a couple of walltes/card holders
the one with the tracks is for a friend at work
the other one is mine
thanks for looking
all comments welcome
Thanks
David
Nice croc case! :thumbsup: Your sttching is coming along!!
Thanks Storm
David
Edited by dscott
NICE LOOKING CASES ......... :red_bandana: WHERE DID YOU GET THE CROC LEATHER?
Edited by Luke Hatley
thanks luke
it was in the cut off carts at tandy
it is the inbosed leather
thanks luke
Wow! I have a roll of the same thing and it is not nearly as nice as this one. The hornback ridges on yours look very much closer to the real deal! Sweet!
I likes it i spent about an hour at tandy Sat. just digging through the carts and bins found some good pieces
David
I really like what you've done. But I noticed that the edges/corners are just a smidge off. If you did nothing more than put a t-square on it and true up the sides it would out these over the top and even out the stitch line also.
It would be a 1000% improvement just doing that.(If the foto makes it look off then I take it all back!)
pete
Thanks Pete
after looking at them a little better you are right they are a little off
i just need to keep my stitches straighter
Thanks for your comment take all the help i can get
David
Are you using dividers? If so then true up the edges and corners and use one. The stitching looks good and pretty straight to me. It's the edges that are suspect.
Get the edges perfectly straight and run your divider along it and "voila' " a perfect line to put your stitches.
again= nice work!
pete
Nice work David! I think they look great. I especially like the wallet with the tracks.
thanks dustin that one is for a firend of mine her boy love turkey hunting
David
Nice work. Simple and effective.
