Dave, first thanks for a great tutorial, I've always admired your work. I do have a couple of clarification questions if you don't mind.
1.I understand your brief explanation about the steps outlined above but in the pictures earlier in the post you show the foam being mounted to the seat prior to the back being riveted, do you rivet the back piece first and then glue and trim the foam or vice versa? The text says one thing but the pictures and explaination shows a different process.
2. I've made my bottom pattern with tape as described and added 3/8" onto it, on the top though does your pattern only go to the edge of the top bevel and then get 3/8" added or does the pattern get created from the top prior to the beveling of the foam. I made my top pattern to the edge of the bevel and added 3/8" but it seems that it will be to small for the number of holes that the bottom piece has and as such will not match. Using about 1/4" spacing b/t holes I get 74 holes on each 1/2 of the bottom piece and with the difference in size between the top I cannot get that many on the top pattern without some running together, So my thought was that I was cutting the top pattern to small, but it matched the bevels which aren't that large. The only other difference is that I'm using 1" foam instead of 3/4" but that shouldn't affect the hole spacing..
Does this make sense? Any advice would be appreciated.
  • 11 months later...
  • Replies 91
  • Created
  • Last Reply
Top Posters In This Topic
Posted Images
how many yards of 1/4" kangaroo lace is needed to do a double loop around a Bobber Solo Seat?
  • 2 weeks later...
Your thread never gets old Dave!! You know I am a sucker for good work and maybe one day we will have a cold beer!
Two beers
  • 10 months later...
Sorry for the delay here, I just saw the question today. My estimate for the amount of 1/4" lace is approximately 10-12 yards.
Dave
To the post about having a beer........... that is going to be some bar to include Finland, Italy and the U.S.
David, Great post, I have never done a bike seat but always wanted to. You remember I tried to get you to come to NM to the show. Anyway great job your the best. Is that a standard double loop lace job or some other pattern?
Randy
Randy Cornelius
Cornelius Saddlery
LaCygne, Kansas
Randy & Riley Cornelius
Ride Hard, Shoot Fast and Always Tell the Truth...
  • 1 month later...
  • 2 months later...
The foam goes on first then rivet the back.
What size holes are you using? I use 1/8" holes for the 1/4" lace. My seats had 100 holes around a seat that had a 36" circumference.
Edited by David
  • 4 weeks later...
What do you use for padding?
  • 7 months later...
High density neoprene from Foam and More
do internet search for them.
Dave
