Members AzWmrs Posted January 26, 2010 Members Report Posted January 26, 2010 Hi all, New here. This forum is really great! Lots of good information - thanks! I just got a Singer 29k. Got it all cleaned up and oiled. Thought I had the tension all straightened out, but today I am sewing a patch on and when I sew in three directions (left, right and towards me) it sews fine, when I sew in the direction away from me, the top thread loops and is very loose? I would appreciate any advice. Thanks again, Shooter Quote
Members celticleather Posted January 27, 2010 Members Report Posted January 27, 2010 Welcome to the Forum . . . a bottomless pit of (mostly) useful information! It's worth checking that you have the needle facing the right way in the needle-bar . . . with the long groove to the left. Having it in the wrong orientation can sometimes cause the problems you are experiencing. If you don't have a manual for the machine, I posted a pdf at http://leatherworker...=1entry134713 a while ago. It's for the 29K71 and 29K73, but the information is pretty much the same for most models. Hope it helps! Terry Quote When everyone is somebody, then no one's anybody
Contributing Member UKRay Posted January 27, 2010 Contributing Member Report Posted January 27, 2010 In addition to everything Terry said, you might want to check that you have threaded it correctly. Although it will work, up to a point, with almost any sort of threading, it works a whole lot better if you follow the instructions in the manual exactly. I learned this the hard way but you don't have to. Have fun, 29Ks are great little machines when you have sorted out their foibles! Ray Quote "Some mornings, it's just not worth chewing through the leather straps" Ray Hatley www.barefootleather.co.uk
Members AzWmrs Posted February 16, 2010 Author Members Report Posted February 16, 2010 First I want to apologize for not replying sooner - had a computer melt down! Still trying to recover from it. I have checked the needle position and the threading accuracy and I believe that I have followed both correctly. I tried adjusting the different tension thumb screws and thought I had it close, but now it is completely off and won't sew correctly at all. I would love to start back at square 1, but I don't know what to do from here. Thanks again for the suggestions and any more that might be posted. I would be extremely grateful for the help. Quote
CowboyBob Posted February 16, 2010 Report Posted February 16, 2010 (edited) Hello Shooter, you mention that it isn't sewing correctly at all,so what is it doing? Edited February 16, 2010 by sewmun Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members akasanchez Posted August 10, 2014 Members Report Posted August 10, 2014 I have a singer 29k70 and a user manuel. The manuel decribes my problem as "needle thread tension to strong". Can someone help explain what i can do to regulate my stitches? Quote
Moderator Wizcrafts Posted August 10, 2014 Moderator Report Posted August 10, 2014 (edited) The "needle thread" is the top thread that is feeding off of the spool of thread on top somewhere. If that thread is too strong, or tight, try backing off the knurled adjuster nut for the top tension disks. Also, check the path of the thread to see if it has twisted around something, or itself. If the spool is sitting on the little thread platform bolted onto the right-front of the machine, put something slippery under it, like a washer cut from felt. Eliminate as much drag as you can, along the thread path. I went to the extent of installing regular industrial thread stands on my patchers. They feed up, off the top of the spools, and have no appreciable thread drag. Make sure the bobbin thread feeds under the tiny spring in the outside cutout of the bobbin case, then goes up through the tiny hole over the spring, and that the tension screw has enough tension to apply a little resistance, but with a smooth pull. If your machine uses the larger bobbins, you also have to feed the bobbin thread through the top hole in the center post on the bobbin case. Edited August 10, 2014 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members cdthayer Posted August 10, 2014 Members Report Posted August 10, 2014 (edited) If you’re using a cone of thread, here’s how I feed the cone thread on my Singer 29K70. I use the small cones because I normally just do repairs, so I don’t use much thread, but I need as many colors as I can find. I used an old peanut can to set the cone in on the front side of the pillar, routed the thread up around the original thread spool pin, and on to the lubrication pot and beyond. Later on, I cut the top out of a Justin Roper Boot, stuffed a plastic butter dish down in it, and then put the peanut can inside of that. The peanut can keeps the thread from catching on the boot pull-on straps when it feeds off, and the boot top looks a little better than the peanut can by itself. On another machine that I have at home, I had to turn the boot top inside-out to keep the thread from catching without a peanut can inside of it.I probably should make something a little more permanent like Wiz was talking about, but it’s been working for several years. On another note, my machine is stored near the large front windows of the shop, so the boot top keeps the sun from shining directly on my thread cone when not being used.CD in Oklahoma Edited August 10, 2014 by cdthayer Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Members Darren Brosowski Posted August 16, 2014 Members Report Posted August 16, 2014 Could be as simple as a burr in the needle plate that only comes into play when sewing in a certain direction. Quote
Members akasanchez Posted August 21, 2014 Members Report Posted August 21, 2014 I have a singer 29k70 and a user manuel. The manuel decribes my problem as "needle thread tension to strong". Can someone help explain what i can do to regulate my stitches? I have a singer 29k70 and a user manuel. The manuel decribes my problem as "needle thread tension to strong". Can someone help explain what i can do to regulate my stitches? Quote
