Hi Everybody,
Ever had a project, that just seemed to fight you ALL the way??? Well,,, here's mine!! hehehe But I think I finally won!! It's a Notepad Holder for a friend's Daughter. He told me he wanted "Muted" Fall colors on it. After getting the front tooled,,, & started the dyeing process,,,, I soon realized that even as hard as I was attempting to get "Muted" colors,,, they were still to bright for him. Soooo what I did was,,, after I got done with the dyeing,,, & it dried completely. I kind of Scrubbed it with my NeatLac replacement, which I knew would remove, some of the Depth of colors. That helped,,,, but it still was a "little" too bright still. Soooo I smeared on a good coat of Antique,,,, & kept wiping it off until I got the colors, that I knew he was wanting. Of course I topped it with some Tan Kote, over the Antique. The coloring process, only took about 15 hours of work. About 2 1/2 times longer than normal. I had to make the spine cover 2 times. I made the inside flap a second time when I found out his Daughter is a Real estate Appraiser,,,, that uses a calculator "all the time".
Of course, while working on this,,, I just had to make the "Rapid Repeater",,, & make 3 more Mauls. So,,, needless to say,,,, I'm glad this battle is over! Now,,, just 10 Mauls to make before the 15th,,,, Ed the"BearMan"
Ed the"BearMan"
polarb1717@aol.com
Beary: BearMauls@yahoo.com
http://tinyurl.com/BearMauls "The Best tooling mauls available today!"
I know what you mean. I'm glad you kept at it though, it turned out great! I really like what you did on the back too. That's just neat.
Ed this is the finest yet!! Ilove the colors and carving on the front and the back and spine all work really well. Congrats on a wonderful piece of work!!!
Storm
Please keep in mind that unless I ask for anyones critique I do not want nor require same.
Nice! I REALLY like it and I'm generally not a big fan of the colored stuff.
Ed I really like the muted colors better. I think I might even like them muted a little more! For me the muted colors enhance your beautiful tooling where as the more intense colors detract. Im my mind this is an example of less is more. Beautiful stuff...thanks for sharing.
Bobby
Ed,
Great colors for fall. I would agree with Bob that more muted or subtle colors might have made more visual impact. Even with that said...nice.
You have been a busy man with the handy-dandy repeater and 3 mauls along with this piece. Good luck with the other 10 mauls.
Regards,
Ben
Thanks Clay, Storm, Bobby, Ben, & Bex,
Thank You all so much for the wonderful compliments! The Muted colors have grown on me. So I guess the customer was right after all,,, hehehe The "Rapid Repeater",,, (I kind of hate calling it that), really did make the stitching go faster, & a lot more uniform. The design, was an effort on my part to revive some of Ketchums, & Porja's inspired designs.
Also, the flap that holds the notepad in, is 5/6 oz Horse hide. If any of you haven't used any of that yet,,, you might want to. Horsehide is a finer grain, & somewhat tougher skin, that is Very smooth. It also takes an edge like glass. Horsehide is a little tougher to tool , & cut,,,, but it's no worse than some of the cowhide being marketed out there. If you want to try some, make sure you get the "Soft Rolled" if you are planning on tooling it. Horsehide has been used for a LONG time. Some of the best holsters use it. If you use it, be aware that it darkens quite a bit with oil,,, & it doesn't take dye quite as well.
As far as being Busy,,,, well,,, I really need to be, as working on "stuff" helps keep my mind off the chronic pain situation I live with. Distraction is a good thing,,, at least in my situation. Several battles with large animals, a couple "sprint Car accidents, & standing on concrete for 30 years just distroyed my back.
Thanks again everybody,,,, Ed the"BearMan"
Ed the"BearMan"
polarb1717@aol.com
Bear
That's a wonderful notebook. I agree with you and everyone else that the muted colors make the piece 'a stand-out'. Keep up the good work.
Happy tooling
Tim
It's hard to fail, but worse never to have tried to succeed.
Theodore Roosevelt
  • Ambassador
as usual- beautiful work Ed!
Question...
I have made many, many notebooks/albums, but never a 3 piece with a spine. Is the spine the last piece to design(measure), and do you measure it flat laid out onto the 2 side pieces, or do you do the side pieces and "fold" it around to measure before cutting.
I'm going to do a 3 ring binder so it will be much thicker than yours.
anyone else(BOB!) who wants to chime in would be appreciated.
pete
That's beautiful Ed, I love the colors. What weight leather did you use for the outside pieces?
