I finally have some time to play with my sewing machine.
Several questions:
1) Does everyone stitching with a machine groove the front side for the stitches? I tried with the groove and without. Like the stitch down level with the surface of the finish leather.
2) Any notes of importance on stitching around the shaped end of a belt? I find it difficult to keep the stitches consistent in length. Stitching manually but haven't determined how I
should move the leather in reference to the needle. I assume the needle should be into the leather before you move it going around the end.
3) I had obtained a smooth needle plate before Christmas. The "dogs" won't adjust down far enough to keep from hitting the bottom of the plate without removing the entire
mechanism and I am not going to do that. My Son-in-Law has a mill so he is going to machine the back of the plate for me so the dogs don't hit.
4) I have adjusted the pressure on the presser feet so they have just enough down pressure to keep the leather moving. Unfortunately they still make marks in the finish leather. I
should add that my presser feet are smooth.
When using a factory dyed leather the marks are very troublesome, the large modeling spoon will not remove the marks to my satisfaction. I will continue to work on that
problem but I am certainly open for any and all suggestions.
BTW: I am on a Consew 206RB5. Have spent some time seeing what parts do what. LOL
ferg
Edited by 50 years leather
I had some of the same problems when I did my first few belts.
Yes, . . . matter of fact, . . . I groove both sides. I do my edges first, sanding and edging them to an acceptable final finish. Sometimes I even go ahead and burnish them. This is the trick necessary to getting the backside stitches in the groove where they need to be.
I learned to position the stitch groove in the window on my presser foot so I could dictate to the machine where the next stitch would land as I made the turn. I actually move the belt while the needle is all the way down, . . . pivoting on the needle itself.
I also drastically removed pressure from my presser foot. My belts or holsters will feed, . . . but I have it so loose that it just barely feeds, . . . and I have practiced to the point that I almost force feed it into the machine. That did get rid of those nasty marks you were talking about.
My machine is a Tippmann Boss.
May God bless,
Dwight
PS: They beat the heck out of a sail needle and a palm, . . . those sewing machines !!!
Edited by Dwight
www.dwightsgunleather.com
May God bless,
Dwight
Thanks Dwight.
ferg
  • 4 weeks later...
Kinda funny, but true story.
I went to a nearby industrial sewing machine retailer and asked him how I could eliminate the ugly marks on the back of my work......
"can you help me get rid of this?"
He said "Sure I can"
"oh yeah? how??
"buy that machine" as he points to a REAL stitching machine.
Short story longer....he then explains to me why the machine I was trying to use was not the right kind of machine for the work I was trying to do on it......and showed me that the new machine he was pointing at is.
While the machine I had was rated to sew through 1/2" of material, (it could sew through 1/2" of veg tan) it was really meant to sew thru material that does not mark....canvass, webbing, etc.......
Live and learn....again......I hope to pick up that new machine this week:thumbsup:
Rayban
www.rgleather.net
"oh yeah? how??
Ray,
I hope you enjoy your new machine. With unending help from Wiz and a lot of experimenting with foot pressure etc., I have very little problem with the marks on the leather I am sewing.
Even with time spent, it was cheaper than a new machine that may do the same thing.
just my .02
ferg
Yepperz...Wiz had substantial input in my decision.
Rayban
www.rgleather.net
