Members JS22 Posted February 1, 2011 Members Report Posted February 1, 2011 What's the best way to prepare a straight edge before using the strap cutter? I saw the tutorial in this forum using the box cutter. I have tried a few practice cuts on scrap with a small ruler and an exacto knife. Although I get a straight line, the cut is not exactly vertical from top cut to bottom cut. What am I doing wrong, or is the exacto not the preffered cutter of choice? Quote John jscustomleather.com sales@jscustomleather.com
Members RobDude30 Posted February 1, 2011 Members Report Posted February 1, 2011 I have a 60" long aluminum ruler and a heavy duty snap-off blade knife that I use to get the first straight cut. I use a fresh section of blade and hold the ruler steady with heavy pressure from my left hand and right knee while I make the cut with my right hand. Works just fine as long as the ruler doesn't slip. Quote
Members Dwight Posted February 1, 2011 Members Report Posted February 1, 2011 It depends on how straight you want that first line. An aluminum ruler that has a layer of cork glued to the bottom side does not slip and slide hardly at all. A drywall knife with a new blade that has been stropped 50 -75 licks will cut through any 9 oz or less leather I have ever encountered, . . . and do it in one pass. A "last resort" that will give you a straight enough lne for most things, . . . is the old carpenter's chalk line. Just don't get too much chalk on it as you pull it out. It works well if you have a side you are trying to even up or something like that. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Moderator bruce johnson Posted February 1, 2011 Moderator Report Posted February 1, 2011 I use a 6 foot ruler and a 45 mm roller blade cutter. The roller blade will got through about everything up to 14 oz. With that it wll score it enogh that a quick pass with a roundknife in the cutline will do the job. Quote Bruce Johnson Malachi 4:2 "the windshield's bigger than the mirror, somewhere west of Laramie" - Dave Stamey Vintage Refurbished And Selected New Leather Tools For Sale - www.brucejohnsonleather.com
Members Kevin Posted February 2, 2011 Members Report Posted February 2, 2011 I mark it with a straight edge, hang it off the table and cut it with a round knife. THEN I use a strap cutter and cut a 1 1/4" strap, then turn the strap around and cut a 1" strap which leaves your 1/4" with the uneveness. I can always use a 1" strap and I use the 1/4" piece to tie up the side after I roll it up. Kevin Quote
Members jasonsmith Posted February 3, 2011 Members Report Posted February 3, 2011 What about using something thick so you can keep the blade vertical vs. a thin ruler that would let the blade lean when cutting? Quote
Members Gawdzilla Posted February 3, 2011 Members Report Posted February 3, 2011 I use a 6 foot ruler and a 45 mm roller blade cutter. The roller blade will got through about everything up to 14 oz. With that it wll score it enogh that a quick pass with a roundknife in the cutline will do the job. Bingo! I always use a roller blade for true vertical cut. If you get some 1/4" bar stock (~$6.00 for three feet) you can run the blade down that to guarantee it stays true. Quote
Members jasonsmith Posted February 3, 2011 Members Report Posted February 3, 2011 Bingo! I always use a roller blade for true vertical cut. If you get some 1/4" bar stock (~$6.00 for three feet) you can run the blade down that to guarantee it stays true. Where do you get bar stock at? Quote
Members Gawdzilla Posted February 3, 2011 Members Report Posted February 3, 2011 Where do you get bar stock at? Lowes. Home Depot, places like that. It's best to test the straight edge before buying it, btw. I find a 36" level and check for light gaps when they're butted together. Aluminum stock usually has a cleaner edge, but the weight of the steel stock helps keep the leather in place. A couple of quick grip clamps and it's not going anywhere anyway, however. Quote
Tree Reaper Posted February 3, 2011 Report Posted February 3, 2011 I use a steel framing square, works for me. If the leather has a curl I'll clamp it down prior to cutting. Kevin. Quote
