Members simran Posted May 26, 2011 Members Report Posted May 26, 2011 (edited) That doesn't exactly help much..... Here's my deal - I'm not sure whether I need a pedestal stand, or a table, at this point... So I'm shooting in the dark here, and trying NOT to end up buying 2 tables... I'm wondering if I bought a "table" (as opposed to a pedestal), if I would be able to make an adaptor-piece (out of wood?), to essentially convert from a "cylinder arm machine" (on a cylinder arm table), to a "flat bed" (by adding that piece to the table) ?? Any help is appreciated...... Signed, Clueless DenverLeather, I think most anyone you'll talk to will recommend a stand. A stand allows the operator to stand and maneuver odd sized objects like saddles, collars & odd shaped bags or luggage around under the needle. It's harder to do sitting at a table. That's just me! All you really need to do is figure out what type of work you'll be doing. Edited May 26, 2011 by simran Quote Simran
Members amuckart Posted May 27, 2011 Members Report Posted May 27, 2011 Since getting a commercially made stand shipped to New Zealand is prohibitively expensive, and I can drive a welder, I've been contemplating making a stand for my 45k (once I've got the damn thing back together again, that is) An idea that's been stuck in my head for a while is building in the gas prop mechanism from an office chair to let me adjust the height easily. I figure if a gas prop can deal with my fat 110kg butt sitting on it it'll deal with pretty much any sewing machine out there, and they come in all sorts of heights. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Members simran Posted May 27, 2011 Members Report Posted May 27, 2011 Since getting a commercially made stand shipped to New Zealand is prohibitively expensive, and I can drive a welder, I've been contemplating making a stand for my 45k (once I've got the damn thing back together again, that is) An idea that's been stuck in my head for a while is building in the gas prop mechanism from an office chair to let me adjust the height easily. I figure if a gas prop can deal with my fat 110kg butt sitting on it it'll deal with pretty much any sewing machine out there, and they come in all sorts of heights. That's an interesting idea! Quote Simran
Members stanly Posted May 27, 2011 Members Report Posted May 27, 2011 That's an interesting idea! considered converting auto hoist/stand to your needs? I'm not saying there is one near you, but I like to adapt existing devices when possible. http://www.harborfreight.com/2000-lb-foldable-engine-stand-67015.html http://www.harborfreight.com/1-ton-capacity-foldable-shop-crane-93840.html Quote
Members Anne Bonnys Locker Posted May 30, 2011 Members Report Posted May 30, 2011 Since getting a commercially made stand shipped to New Zealand is prohibitively expensive, and I can drive a welder, I've been contemplating making a stand for my 45k (once I've got the damn thing back together again, that is) An idea that's been stuck in my head for a while is building in the gas prop mechanism from an office chair to let me adjust the height easily. I figure if a gas prop can deal with my fat 110kg butt sitting on it it'll deal with pretty much any sewing machine out there, and they come in all sorts of heights. Try the base off an old dentist or barbers chair as they will be more stable. I like the office chair strut idea but fear you will bounce as you stitch. Quote Darren Brosowski
Members amuckart Posted May 31, 2011 Members Report Posted May 31, 2011 Try the base off an old dentist or barbers chair as they will be more stable. I like the office chair strut idea but fear you will bounce as you stitch. Oh, I'd have cam clamps to fix it in position, I was just thinking of the gas prop as a way to allow the height to be easily adjusted with weight on the table. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
CowboyBob Posted May 31, 2011 Report Posted May 31, 2011 The gas shock sounds like a great idea but I think most people have an idea if they want to sit or stand to sew & rarely change once they get it to their preferred position. Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members amuckart Posted May 31, 2011 Members Report Posted May 31, 2011 I get back problems and quite bad RSI, so the ability to adjust even a little bit up and down can make a big difference to me. I've been working on how to get four low-weight props synchronised so I can put them in the legs of my desk for that reason. Quote -- Al. Medieval Stuff: http://wherearetheelves.net Non-Medieval, including my machines: http://alasdair.muckart.net
Moderator Wizcrafts Posted May 31, 2011 Moderator Report Posted May 31, 2011 Maybe this topic will cause some entrepreneur to come up with an affordable (?), not too difficult to install (with tools) add-on kit that allows one to alter the height of their pedestal sewing stand, with a lever. It would have to be a bolt in/on attachment for common power stands. Also, any changes in the height of the table top requires a matching change in the length of the chains from the two pedals on the base. Or, spring-loaded take-up idler wheels would be needed to maintain the proper amount of chain slack at all anticipated heights. No, I don't intend to build one, so don't throw it back at me. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members leatherkind Posted October 17, 2012 Members Report Posted October 17, 2012 I also found this type of table quite handy. http://leatherworker.net/forum/index.php?showtopic=34847&st=15#entry218917 Quote
