I have a Singer 168W101 that I got for my shop. After receiving it I found that the motor and clutch are not the original ones. It is 1/3 hp 1750 RPM with same style external clutch assembly. However the integrated pulley on the pressure plate is way to large and runs the machine at probably 5k SPM instead of the 2900 it is supposed to. Any resources out the to find a smaller pulley/pressure plate assembly? Feathering the clutch doesn't even come close enough to be able to sew with it. BTW it zips through 3/8 leather like it is liquid butter. I have no doubt it would stitch through your femur!!!!
There are several things that you can do , you can swap out the motor for a servo motor that will give you total control of the speed from 0 and up , you could check the local hardware or farm store for a smaller pulley to put on your existing motor or you could put a larger hand wheel on the machine ..
If you do a bit of searching you will find more info on all of the options ..
Hope that helps .
HAHAHA Welcome aboard. My femur huh?
I once stitched my fingers crossed waiting for a machine, but never thought of the femur.
Two things you could do:
A: buy a servo motor like the SERVPRO
B: Put a really big pulley on top your machine, and a littlee tiny smalll itsy pulley on the bottom
Once believed in GOD and the DOllAR...... Hello God!
The motor Kayak was calling the "ServPro" is actually named the "SewPro" 500GR. Our member dealer Toledo Industrial Sewing Machines sells tham at a good price, with a 2" pulley for leather sewing. I have this motor and won't sew without it.
Some of the bigger, harder to turn machines have a speed reducer system installed between the motor and machine, under the table. This slows down the maximum speed to a much more leather friendly range of a few stitches per second. Without the 3:1 reducer the SewPro 500GR has 1500 rpm at full speed.
If you want to keep your motor, measure the diameter of the output shaft. If it is 3/4 inch, that is the standard industrial sewing motor pulley diameter. Any sewing machine dealer can sell you a smaller 3/8" or 7/16" v-belt and pulley in 3/4 inch ID. Most leather sewing steups have a 2 or 2.25" motor pulley.
Installing a smaller pulley necessitates buying a shorter v-belt to compensate for the difference in length from the original. That allows you to set the motor-to-machine belt tension in the mid range of the position adjuster bolt, on the bottom of the motor.
Posted IMHO, by Wiz
If I could swap pulleys for a smaller one it would be a simple fix. However, the pulley and pressure plate are one piece with a bearing in the center to allow free wheeling on the motor shaft. The bearing is a friction fit on the motor shaft. The pressure plate is pressed against the clutch/flywheel plate which is attached with a keyed slot. When the foot pedal is pressed it moves the pressure plate/pulley against the clutch/flywheel to drive the hand wheel. This is how the original motor was set up for these machines. The machine comes to a stop via the foot pedal which when pressed the opposite direction applies a brake against the edge of the pressure plate. Maybe I am screwed and will be forced to go the route of another fix rather than a smaller drive pulley/pressure plate . The one that's on it now is 4.25" and the original called for a 3 .5" . Sure wish it was as simple as replacing a standard pulley. BTW the machine is OLD but runs like......well a sewing machine!
I am wondering if the Servpro would have the power to slowly sew through 3/8 leather for sheaths and scabbards.
That motor is not a ServPro, but a SewPro 500GR. It is sold by Bob Kovar, at Toledo Industrial Sewing Machines (866-362-7397). The motor bolts onto the underside of the table, usually into the three holes from the original clutch motor. If your motor has three carriage bolts, in a long triangle; two on the left and one on the right, centered, this motor will drop in. If the holes are too far to the left, you will have to drill new ones, or buy a new table top; pre-drilled, cut-out and slotted.
Since your external clutch has a 4.5" pulley and a SewPro 500GR has a 2" pulley, you will need a new v-belt, about 3 or 4 inches shorter (this motor sits closer to the table, losing one inch to start with).
To answer your question about the motor's capability, yes, the SewPro motor will have more than enough power to plow through 3/8" of any leather. I have this motor driving my National N300 walking foot machine and it plows through 7/16" of leather, without bogging down or dropping out. That is with a #22 or 23 leather point needle.
Edited by Wizcrafts
Posted IMHO, by Wiz
You think we could shrink you handle down to "archer"
Wiz is being really hard on my speln, I think I'm goin to market a servpro couse it sounds kinda good.
That motor wiill taake, I think, a 3/8" bolt, kinda pointed at the end, and rope of somekind for thread.
it's reallly realllly strong.
#/3/4 Inch leather, No Problem!jawdropper.gif
So what is this SEWPRO 500 going to run me? No I don't have a 3 legged mount. It as a cast carriage designed for 4 bolts. It wouldn't be hard to make a plate for the motor and mount it to the existing carriage.
Kent
A buck three eighty nine
Not really. About $180 plus shipping of about 11 to 15 dollars.
Posted IMHO, by Wiz
