When you say soaking, do you mean in the dye or with water? I'm assuming water.....
I do indeed mean soaking in water. I wet stitch my stuff, and even if the dye work is a little splotchy at the start, by the time I'm done stitching, after repeatedly submerging my piece, the dye is a lot more evened out.
I also use almost exclusively the old Fiebing's Dye. I have found that the new green label Fiebing's acetone based dye migrates much more when the leather is soaked in water.
Can you cut the oil die with other oil?
I might not be around in a hundred years but if I get good enough, maybe some of the thing I create will be.
So I am making some belts for a costume and they were cut from vegetable tanned leather from Tandy's leather. I didn't really know what I was doing and just applied the dye some pieces that were dry, some that were damp, and some that were wet. When they were dry they were all very stiff and some were very discolored- blotchy and uneven coloring. Some of the belts' edges were slightly curled up too. What are the steps I should take to dye vegtan leather and get a good result? I am using oil-based dye, Fieblings (I think I spelled that wrong). I just would like some clear steps on how to dye my leather and have everything look nice and even! I'm a complete newbie.
Mags, this is pretty much SOP. The neatsfoot should take care of it. Next time before you dye, clean it with rubbing alcohol to get dirt, oil from your fingers, etc. off and while it's damp from the alcohol apply the dye with a dauber, piece of shearling, or piece of soft cloth - you can spray it if you have a sprayer - an air brush.
Don't over oil it. You'll have to learn by doing, but too little is better than too much. You can always apply more oil. Pure neatsfoot is best. I wouldn't mess with compound neatsfoot.
As mentioned Lexol - real good stuff in my opinion. Esp. if working with natural russet as it doesn't darken it. It's easier to work with than neatsfoot, soaks in better, less residual esp. at the surface.
After you oil, let it set at least 24 hours. Neatsfoot may take even longer than Lexol. I like to let a fan blow over it. Next step is to buff heck out it. Once it evens out and you're not getting rub-off you can apply a finish coat - or - another coat of dye if it needs it - it usually doesn't need any more dye if you cover it well. Plenty of people dip dye things like gun leather so you can daub it on heavy and not go overboard.
From you last post you had pretty much figured it out. You on the right track. Don't be discouraged with a few splotches and uneven hues. Where ever you burnished, slicked, matted, i.e. compressed and sealed the surface you'll have to add more dye and give it a change to penetrate those less porous areas.
You're getting there!
Wow, thanks so much for this! All this is so helpful!! Its kind of hard to find exactly what I need since everyone's leather situation is different. I will definitely be keeping your advice in mind when finishing up my belts, the color is pretty much even now and I'm about to go apply the neatsfoot oil :)
  • 2 years later...
I guess I do belts a bit different: for dying, . . . I pour about a pint of dye into a 11 x 14 cake pan, . . . and snake my belt through the liquid allowing it to remain perhaps 5 seconds in the dye, . . . always face up throught the dye, . . . then hold it with both hands and watch the excess dye on the top of the belt migrate down into the leather. I then lay the belt on a piece of cardboard, . . . in a 20 inch or so circle, . . . resting on the bottom edge fo the belt.
About 20 minutes later, . . . I flip it to the top edge, . . . give it another 20-30 minutes, . . . hang it up by the buckle end to finish drying. It hangs for the balance of 24 hours.
I wish the best to any and all who are thinning their dye with water, . . . the dye is basically a petroleum based product, . . . the oil simply will not mix with the dye, . . . and the same goes for wetting down leather before dying it. The water displaces the dye, not allowing it to penetrate, . . . thereby giving a blotchy result.
May God bless,
Dwight
www.dwightsgunleather.com
  • 5 years later...
I am using water based dye and looking to get the leather Through dyed, I have tried to soak the leather in a basin covered in the dye however it only penetrated about 1mm from the surface of the leather. How do I get it to through dye?
Leather is Veg Tan and I let is soak for about 10 mins, it took 4 days to dry out but it is winter so very cold
Thanks.
One thing you can do to help your leather dying process, . . . first give it a good coat of neatsfoot oil.  Don't use the oil "compound", . . . get the real oil.
Use a cheap bristle brush, . . . coat the hair side (smooth side) liberally with the oil, . . . then lay it up to dry.  Don't "hang" things like belts and straps from one end,  . . . lay them on one edge, curled up on a piece of cardboard, . . . leave them for 24 to 36 hours, . . . the color will return almost perfectly to where it was when you started.
THEN, . . . slowly curl it thru a pan of dye, . . . I use 9 x 14 cake pans, . . . and the leather piece will stay in for about 6 to 10 seconds, . . . depending on what I'm dying.
Again, . . . don't hang long or large pieces by one end to dry, . . . lay them on cardboard, . . . put little blocks under them at various places, etc, so air gets under them as well.  After they have lain flat for a couple hours, . . . you can hang them then if you want.
If it isn't dyed to your satisfaction, . . . re-oil, . . . then re-dye.
Works for me.
May God bless,
Dwight
Thanks.
In my opinion there is something wrong.  Water will soak through veg tan leather, so a water-based dye will also.  If it is not, then there is something "foreign" preventing the dye from going through.  There may be s conditioner, an oil or wax that has been applied previously.  If you have soaked the leather and it still will not penetrate, by all means give Dwight's recommendation a try.
