Members mandyregal Posted October 18, 2011 Author Members Report Posted October 18, 2011 First I want to thank everyone for their suggestions. I forgot to add that initially I tried the other needle you suggested, the Lok eye needle. The little prongs didn't hold the lace in either. So that's when I tried the round Perma Lok needle. So, I'll try some of your suggestions and report back. Thanks again. Quote
Members McJeep Posted October 18, 2011 Members Report Posted October 18, 2011 found a wee trick for cutting the taper on the lace (I use the 1/8 lace a lot and it's hard to hold it to cut the taper) So I started using a utility knife blade by itself, lining it up to the angle I want, and tap with the mallet - nice clean points for screwing into the permalock every time Now if I could learn how to join two pieces rather than having to braid the ends into themselves when starting a new piece of lace, I'd be happy ;0) Quote "I gotta have more cowbell!" Cristopher Walken - SNL
Northmount Posted October 18, 2011 Report Posted October 18, 2011 I use a curved perma-lok type needle bought from Tandy about 45 years ago. Lost it a couple times and luckily found it again. I decided recently to get a couple extra needles. The new ones are way too thick. My old one works for 3/32 and 1/8 lace with no problems. I'm going to take a file to the new ones and see how much I can remove from the tip. The tips look like an elephant stomped on them! I have found good perma-lok needles are far better than the spring leaf types with a couple barbs. They just don't hold on for tight pulls. If you break the lace off flush with the end of a perma-lok, heat it up with a match or lighter and burn the lace out of it. Tap the ash out, clean off any soot, and go back to work. It has only happened to me once, so I am a little more careful about how tight the pull is. It it's too tight, I enlarge the slit a little and make sure the layers are properly glued and lined up. Happy lacing! Quote
Members mandyregal Posted October 21, 2011 Author Members Report Posted October 21, 2011 Ok, I finished my purse and it came out really nice. Initially I used the lok eye needle and I must have gotten two duds. The first one snapped when I opened it to insert the lace, and with the second one, the prongs snapped off when I lightly tapped it with a mallet to seat the prongs into the lace. At that point I got frustrated and had to go eat a bowl of icecream. That always seems to help when I'm frustrated. I tried the jumbo permalock needle and I couldn't get the lace to stay in, I think the they make the new ones with the threads too shallow. I used one that an old timer gave me and I could really tell a great difference. I guess the old saying holds true-- they really don't make em like they used to. Plus, I really didn't like trying to use a round needle with flat lace. It seems you could twist the lace too easily. In conclusion, I ended up ordering more lok eye needles and that did the trick. I don't know if the ones I had been using were old and brittle or what. But the new one worked for me. I heard some people make their own lacing needles out of old soda cans, anyone tried that?? Thanks again for all your help!! Quote
Members ramrod Posted October 21, 2011 Members Report Posted October 21, 2011 when i use the lok eye needles, i will skive and taper the lace. then i'll push the point of a small razor knife through the lace where the little barbs will contact it. that way, the barbs will penetrate the lace completely and make the perfect hold. i've also used a pair of pliers to squeeze the needle and that will also set those barbs. it makes a nice little snap sound when they seat. Quote
Members cipher Posted December 21, 2011 Members Report Posted December 21, 2011 So... does anyone know where you can buy the brass "Life Eye" needles? The kind you screw the lace into? I have two small ones, but would like to buy a few more. Mine have "Life Eye" name pressed into the brass... Thanks... Quote
Members ramrod Posted December 21, 2011 Members Report Posted December 21, 2011 i got mine at tandy. i can't remember when or how much it was, tho. Quote
Members cipher Posted December 21, 2011 Members Report Posted December 21, 2011 i got mine at tandy. i can't remember when or how much it was, tho. Thanks ramrod, but it seems they only have the perma locks ones now... :-( Quote
Phatdaddy Posted December 22, 2011 Report Posted December 22, 2011 I couldn't find a picture of the Life Eye, is anyone able to post a pic that I could see the diff between that and the perma lock ones? Kevin Quote
electrathon Posted December 22, 2011 Report Posted December 22, 2011 I couldn't find a picture of the Life Eye, is anyone able to post a pic that I could see the diff between that and the perma lock ones? Kevin This has been one of the most confusing threads ever. As best as I can figure out, the only difference between a life eye and a perma loc needle is the name. Here is a link showing life eye: http://books.google.com/books?id=BX7KMhYk_B4C&pg=PA171&lpg=PA171&dq=life+eye+needle&source=bl&ots=fapS2n5Vot&sig=l_OAUNZQ7XnLYIHcXfA0e2zlYbo&hl=en&sa=X&ei=K1HzTtD_NaKniQL_kMykDg&sqi=2&ved=0CB0Q6AEwAA#v=onepage&q=life%20eye%20needle&f=false Look on page 171. Both are round needles with a round hole in the end that is tapped inside the hallow tube so you can thread the lace inside. As best as I can tell, the only way for a layman to tell them apart is to read the name brand on the side of them. I stand by my original statement: Round needles are for round lace, flat needles are for flat lace. I want to add one more line: Round holes are for round lace, flat holes are for flat lace.This seems so simple. I am guessing that a lot of people use way over sized holes when lacing, making it seem like the perma loc needle fits easily (holes the size of a Tandy kit for example). If I am mistaken, someone please correct me. If you want your lacing to look good, use smaller holes, closely spaced together and larger lace. I have posted a few pics of what my lacing looks like when done this way (rawhide has also posted pics of his work in the past, he crowds his lace too) in other threads. I see lacing on some peoples work on here and do not understand how it can be so inconsistent. Lacing is very easy, but it also takes a lot of time. The two prong needles are crap. The lace constantly falls off them and just make you frustrated. Lok eye needles hold and hold well. From a pull on them and they stay on perspective they are at least 5 times stronger than any other needle I have ever used. A lot of people confuse lok eye needles with two prong needles, they are a world apart. I do acknowledge, lok eye needles do not last very long. If yo want to lace 5 different items with one needle, it likely will not happen. But they are cheap, just replace them. Quote
