Hello everyone. I had high hopes of getting a new machine but good ol' uncle sam killed that dream so.... I am purchasing a new servo motor from Bob at Toledo and I was hoping some of you could shed some light on mounting it.
I have an old open clutch motor that has a 4 hole pattern and my new servo will have three. Will at least two of the holes line up making the third hole easy to mark or will i have to drill 3 new holes in my table? if I do need to drill 3 new holes, what are my main concerns? how critical is the alignment?
Thanks,
Rich
Rich Radenbaugh
Suemi Designs
www.suemidesigns.com
You may or may not be able to use the rear two holes with the new motor. If yes, you need to drill one half inch diameter hole dead center in the front, at the forward distance the frame dictates. However, it may not position the pulley in the right plane to line the belt up with the motor pulley. Your goal is to have the motor pulley line up with the machine pulley. If the existing holes are close, but no banana, elongate the rear holes forward, then drill the new front-center hole where it needs be.
The motor has rubber mounts that have long slots in them. This allows you to move the motor along its central axis (fwd/bkwd).
You will need to remove all of the old wiring and the old switch box and rep[lace it with the new one. If you are careful when removing the big wood staples securing the AC cords, you can pound them back in when you run the new wiring.
The foot pedal connects to the motor via a slip joint that you can adjust for best positioning. Ensure that the heel goes almost, but not totally all the way down. Leave a small amount of play to the back of the pedal.
The belt is another matter. Two things affect its required size.
1: the size of the pulley, in relation to the original
2: the distance from the underside of the table to the center axis of the motor shaft.
If the old pulley is larger and the shaft is farther away then the new motor, you will be needing a belt a few sizes shorter. I would measure the distance from the bottom of the table to the center of the motor shaft, as well as the diameter of the original and give this information to the seller of the motor. They can compute the probable size of the belt, based on the length of the old one.
For instance: Say the old belt is 44 inches, the pulley 4 inches and the distance under the table to the center of the shaft is 4 inches. If the new motor has a 2 inch pulley and is only 3 inches from the bottom of the table to the center of the shaft, your new belt would be 3 inches shorter, or 41 inches.
The motor is adjustable, but gives best control when it is set close to the center of its vertical travel.
Edited by Wizcrafts
Posted IMHO, by Wiz
If your old belt is still good, but you need a shorter one, you can cut the V-belt and take a piece out like fitting a round leather belt on the old boot patchers. Cut a chunk out and put the ends back together with a hog ring. My Singer 20U33 V-belt is done that way, and it works just fine.
Saves buying a new belt, and having to figure out the length. Just fit the old belt to the new pulley.
CD in Oklahoma
"I sew, I sew, so it's off to work I go....."
My sewing machines:
Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Maybe this will make it easier.
Bob
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Thanks so much you guys. Looking to get the motor soon...
All the best,
Rich
Rich Radenbaugh
Suemi Designs
