Members catskin Posted November 24, 2011 Members Report Posted November 24, 2011 Please can anybody help me. I am having trouble with my machine ( Adler 20-2 ) not forming a good loop for the shuttle to catch some of the time. It will make the most perfect stiches for a while, some times 2 or 3 feet then start missing some times as many as 10 in a row. This is with 346 bonded nylon thead on leather. Here are what I have tried. Changing shuttle. Seemed to have fixed it , went back next day and was back to same problem. Turned the needle slightly one way and the other , no help. Changed needles to try different sizes. !80, 200, 230, 250. no difference. Changed feet, No help. Changed to diferent spools of thread, No help. Adjusted needle bar slightly up and down , no change. Tried sewing different kinds of leather, no real change. Different thicknesses from one ply of about 8 oz. to 5/8 thick (4 plys various thickesses) Most of the above seemed to make a bit of difference but only for a short time. Checked for loose parts. Can't find any parts that seem to have noticeable wear. Now can these cause this kind of trouble. Worn hole in needle plate? Dull point on shuttle? Worn shuttle track? What have I missed? I've had this machine for quite a while though it never got much use, its always been prone to this sort of thing and at times it would get going good without my knowing what I did to make it better. I doubt it can be timing , if it was it wouldn't make perfect stiches for a while then start missing. Any suggestions greatly appreciated. Quote
Moderator Wizcrafts Posted November 24, 2011 Moderator Report Posted November 24, 2011 Needle getting deflected by the layers of leather and heat from friction? Check spring adjustment (more or less travel)? This affects the size of the loop. Worn pickup point is a definite possible maybe. Does your Adler use spacer shims in the shuttle? If so, does the shim match the needle size? Is there any side slack in the shuttle, that coulds cause the point to miss the loop? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members catskin Posted November 24, 2011 Author Members Report Posted November 24, 2011 (edited) Needle getting deflected by the layers of leather and heat from friction? Check spring adjustment (more or less travel)? This affects the size of the loop. Worn pickup point is a definite possible maybe. Does your Adler use spacer shims in the shuttle? If so, does the shim match the needle size? Is there any side slack in the shuttle, that coulds cause the point to miss the loop? Thanks Wiz. First I have this old machine slowed WAY down so heat is not likely, deflection maybe. but on one ply ? Next I MUST check this spring adjustment. Is this the one between the tension roller and the pullup lever? Pickup point seems okay BUT. No shims since I have it. I have 4 shuttles and they have a machined spot of varying sizes just back of the point on the outside edge that I THINK might have something to do with telling you which one should be used for possibly different needle sizes. Side slack seems very small. In fact not noticeably more then on the new Cowboy 4500. The point does not really miss the loop but rather pushs it forward then slips past. I can see what is happening by taking of the plate to the right of the needle. When the loop forms it doesn' always stick out straight from the needle but twists slightly forward ( the direction the shuttle is going) Gotta go check that spring. Edited November 24, 2011 by catskin Quote
Moderator Wizcrafts Posted November 24, 2011 Moderator Report Posted November 24, 2011 Thanks Wiz. First I have this old machine slowed WAY down so heat is not likely, deflection maybe. but on one ply ? Next I MUST check this spring adjustment. Is this the one between the tension roller and the pullup lever? Pickup point seems okay BUT. No shims since I have it. I have 4 shuttles and they have a machined spot of varying sizes just back of the point on the outside edge that I THINK might have something to do with telling you which one should be used for possibly different needle sizes. Side slack seems very small. In fact not noticeably more then on the new Cowboy 4500. The point does not really miss the loop but rather pushs it forward then slips past. I can see what is happening by taking of the plate to the right of the needle. When the loop forms it doesn' always stick out straight from the needle but twists slightly forward ( the direction the shuttle is going) Gotta go check that spring. Yes, the check spring goes between the bottom disks and the take-up lever. It sounds like you need to reduce the travel of the check spring, so the loop forms sooner. Also, change the path the thread takes from the thread stand. Try going through a top hole, around the post, then out the bottom hole, on to the top tension disks. What brand, system and number needles are you using with what thread sizes? Too big of a needle will allow the loops to collapse sooner than otherwise. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members catskin Posted November 25, 2011 Author Members Report Posted November 25, 2011 Thanks Wiz. I tried changeing the travel on that spring,from maximum to no travel and several in between, no improvement. This machine takes the same System 794 needle as the 4500 Cowboy, I am using schmetz I even tried some that Bob sent with the Cowboy. This machine does not have a post with holes to run the thread through. I know 180 is on the small side for 346 thread and 250 might be on the big side but the surpriseing part is they all do the same thing . I would have expected either better or worse with changeing size but there isn't any. I kinda hope Bob or someone who has seen a 20-2 might see this . In case they have some quirk that is unique to them. Quote
Moderator Wizcrafts Posted November 25, 2011 Moderator Report Posted November 25, 2011 Please retime the machine by retarding the hook a few degrees. If necessary, lower the needlebar to place the loop well into the pickup point, and above the eye. Make sure that you time the machine in forward and reverse, at the same stitch length. Timing is more critical for long stitches than short, when reverse is used. If this doesn't improve the situation, change the path of the top thread so it is more inline than otherwise. Are you using typical left twist bonded thread? Is it coming off the spool easily, or with binding? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members catskin Posted November 25, 2011 Author Members Report Posted November 25, 2011 Thanks yet again Wiz for your time and advice. Now after all I said about looking for loose parts I realize I missed one. I tended to be looking at the bottom and finally found that the set screw that holds the top cam that drives the needle bar and takeup lever plus foot lift onto the main top shaft was very slightly loose. Which allowed it to move a few thousandths back and forth on the shaft. It has timing marks on the shaft and cam so I know it is right now. This seems to have all but fixed the problem. Now it only misses the loop on very thick ( near its limit ) but changeing to a thicker needle might help that. If anybody out there knows what those marks on the shuttles mean I sure would like to know. If as I suspect they indicate which shuttle should go with which size needle it would help set things up right the first time. Quote
Members catskin Posted November 27, 2011 Author Members Report Posted November 27, 2011 Well I have it doing good on the thinner stuff, but onthe thicker stuff it still skips. What I see it doing is forming loops on both sides of the needle rather then just on the right side . What can cause this? This makes for a small loop for the shuttle to catch. And there is sometimes deflection on the needle that helps make it miss the loop. If I push the work to the right it catches the loop better. There is not much side play on the shuttle , in fact it almost crushes the thread on the back stroke as the needle is coming down, and brushes the needle as it comes forward to pick up the thread with no leather or thin leather in it. The hole in the needle plate looks rather big (worn ) can this be the cause? Quote
Moderator Wizcrafts Posted November 27, 2011 Moderator Report Posted November 27, 2011 Well I have it doing good on the thinner stuff, but onthe thicker stuff it still skips. What I see it doing is forming loops on both sides of the needle rather then just on the right side . What can cause this? This makes for a small loop for the shuttle to catch. And there is sometimes deflection on the needle that helps make it miss the loop. If I push the work to the right it catches the loop better. There is not much side play on the shuttle , in fact it almost crushes the thread on the back stroke as the needle is coming down, and brushes the needle as it comes forward to pick up the thread with no leather or thin leather in it. The hole in the needle plate looks rather big (worn ) can this be the cause? Get you some Schmetz leather point needles and see if they cure the bad loop problem. What size needle and thread are you using right now? Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
CowboyBob Posted November 27, 2011 Report Posted November 27, 2011 Hello,If it's making a loop on both sides I would say you need to advance the timing alittle,it's trying to make to big of a loop before the shuttle gets to the needle,also on the thicker leather you might need to tighten up the foot pressure so it can hold the leather down. Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
