gtwister09 Posted February 4, 2012 Report Posted February 4, 2012 (edited) Jeff, Quick-Recovery Super-Resilient Polyurethane Foam - Here's the link with part number on McMaster - Carr's website. It is presently on page 3554. The part number is still 86375 K134. http://www.mcmaster....18/3554/=g3tmez It is a open cell foam with skin on both sides. It is also called Poron urethane. It was chosen because it is one of the most resilient of foams as well as being suitable for indoor/outdoor uses. . Also select the firm and the one without adhesive backed foam. Here's the PDF for the page as well. McMaster-Carr Super Resilient Foam for Saddle Seats 3554.pdf Regards, Ben Edited February 4, 2012 by gtwister09 Quote
Members jwwright Posted February 5, 2012 Members Report Posted February 5, 2012 Ben, I got some of that McMaster Carr pad to try last year. It was way too soft to suit me, and I didn't use it. Everyone has their own preferences to be sure, but I like a very firm pad in my inlays. JW Quote www.jwwrightsaddlery.com
gtwister09 Posted February 5, 2012 Report Posted February 5, 2012 JW, Thanks! They also have it up to very firm as well. I don't know if you looked at their firmness ratings on page 3550 (at the bottom) but it shows a car seat at 5, a mattress at 8, tennis ball at 10 and so on. Extra firm and very firm go into cups and life preservers. They also have the listings for the various foams that show their recovery and resistances to weather and oil as Excellent, Good and Fair that could aid in the selection. I know that Greg did like the 8 psi version of the foam. You can also pick up a Firmness Rating Selector Pack in order to determine what you like as well on that same page. Regards, Ben Quote
Members jwwright Posted February 5, 2012 Members Report Posted February 5, 2012 Ben....yes sir. It was the #8 firmness rating that I tried. It was too soft for me.................different preferences for different folks. JW Quote www.jwwrightsaddlery.com
Members Go2Tex Posted February 5, 2012 Members Report Posted February 5, 2012 I've been using the Weaver saddle seat foam, but I generally find that 1/4" just isn't quite thick enough for inlays. So, I usually have to double it or use a thinner piece of foam on top of it. Think I'll try Panhandle, though. thanks for the tip. Unless my math is way off, it looks like McMaster is about 4 times as expensive, and open cell foam will suck up moisture.- Not good for a saddle seat, it seems to me. Is that Panhandle crepe open or closed cell? Quote Brent Tubre email: BCL@ziplinkmail.com
gtwister09 Posted February 5, 2012 Report Posted February 5, 2012 (edited) I was only conveying information and not defending any particular seat foam or vendor. Brent...I have to agree on their costs because I buy almost nothing from McMaster-Carr due to their prices. Others sharing what they like is what this is supposed to be about. Having the ability to make comparisons like JW is worth its weight in gold. There are other factors that impact the weather resistance other than open or closed cell. The skins are another technical aspect that impacts it. As stated below they do provide a scientific means of measuring firmness, recovery from compression and weather resistance. Gum and crepe are usually at the fair end of weather resistance. However they are generally covered in a seat application so ozone, sunlight and such have a limited impact on them which are factors in determining weather resistance. JW....You are so correct. I never tried the material but I would be interested in knowing what the actual PSI hardness is for the crepe as well. From your statement of "very firm" it appears as though you like something that has the same consistency as styrofoam cups. As far as McMaster-Carr they do provide an EXCELLENT analysis of types of foams, uses and features so that you people can do their own analysis/decision. They also provide actual sample packs that have actual data behind them as well as providing you with a means of the "feels right" factor. Regards, Ben Edited February 5, 2012 by gtwister09 Quote
Members GrampaJoel Posted February 5, 2012 Author Members Report Posted February 5, 2012 The foam I ended up using is a white closed cell foam. It's firm enough that it doesn't bottom out. I did select a 1/2" thickness though. I have tested many foams and chose the one I did because of it's firmness and it's cushion effect. All the open cell foams I tested just bottomed out when I sat on them. Even the one inch ones. So I started looking at closed cell foams until I found one that felt nice to sit AND bounce on without bottoming out. It seems like every saddle brought in for seat foam repairs that I get have a scant 1/16" foam, or maybe a 1/4" thickness when the seat is lifted. I just have started using this new foam, so I can't say the lasting abillity of it. But from the get go it feels much better than what I have taken out of other saddles. Now I figure someone will ask what it is called. I can't say. The man who ordered for the auto fabrics shop was gone the day I was in. But the cost was. 13.45 a yard. It was a 56 inch wide so a piece 36" X 56" X 1/2" cost 13.45 plus CA state tax. Joel Quote
Members horsewreck Posted February 9, 2012 Members Report Posted February 9, 2012 Ben, Thanks for the link to McMasters-Carr site, I was able to find the foam you have described. I think I want to start with something firmer than the 8 that JW said he tried. As usual the discussion shifted to cloud crepe, so now I want to take a look at that as well. I will have to get some of both to try. Thanks guys for a brisk discussion, this is what I like most about this site.... Jeff Quote Horsewreck, aka, Jeff M. Hairgrove
Members oltoot Posted September 11, 2012 Members Report Posted September 11, 2012 Hello all. I am in need of some info regarding foam for saddle seat padding. There aren't any foam suppliers in my local area that I know of ( SOCAL) or can find, I need one. Does anyone have a foam supplier they could recommended? Or ideas where to look? Maybe one by internet? Thanks Joel I have been using backpackers closed cell sleeping pads for a long time. Closed cell is IMPORTANT because it doesn't absorb moisture when it rains. I have never had one come back in the 30+ yrs ive been using it. The seat in my own personal saddle (20+ yrs) is just like the day it was finished. Quote
Members CircleZSaddlery Posted April 12, 2017 Members Report Posted April 12, 2017 I wondered if anyone ever got an address and/ or a telephone number for J and J Auto Fabrics?? Quote
