Members kennh Posted April 5, 2012 Members Report Posted April 5, 2012 I called a company to place an order for a Servo motor to replace my old clutch motor on my Singer 111G156. The person who shall remain nameless says to me Why would you want to put a nice servo motor on that old dinosaur? Tried selling me on a new Chinese machine with a large bobbin. My question is are the newer machines around the $1000.00 range better than my old Singer 111? My Singer does have reverse but a small bobbin. Thanks in advance, Ken Quote
Techsew Ron Posted April 5, 2012 Report Posted April 5, 2012 (edited) The 111G156 is still a great machine, not quite an old dinosaur. A servo motor will definitely improve its performance. What kind of items are you sewing? Ron Edited April 5, 2012 by Ronnie Quote Techsew Industrial Sewing Machines Call toll-free: 866-415-8223 Visit www.techsew.com
Members Anne Bonnys Locker Posted April 5, 2012 Members Report Posted April 5, 2012 Have to agree with Ron there. Old does not mean bad! There are times that I have to tell a customer that the machine they have bought elsewhere is never going to do the job they want but it is best to try and get them to do some research on a site like this to find what they need. Quote Darren Brosowski
Members kennh Posted April 6, 2012 Author Members Report Posted April 6, 2012 The 111G156 is still a great machine, not quite an old dinosaur. A servo motor will definitely improve its performance. What kind of items are you sewing? Ron Sewing Light weight leather for upholstery, Is there any rule of thumb for how far you may be able to sew before your bobbin runs out? I know it depends on thread size. Quote
Moderator Wizcrafts Posted April 6, 2012 Moderator Report Posted April 6, 2012 Sewing Light weight leather for upholstery, Is there any rule of thumb for how far you may be able to sew before your bobbin runs out? I know it depends on thread size. If the machine uses a G bobbin, common in Singer 111s, it should hold about 35 yards of #69 thread, or half that amount of #138. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members kennh Posted April 6, 2012 Author Members Report Posted April 6, 2012 If the machine uses a G bobbin, common in Singer 111s, it should hold about 35 yards of #69 thread, or half that amount of #138. So does that mean you should be able to sew approx 35 yards in distance before running out of bobbin thread? Quote
Ambassador Luke Hatley Posted April 6, 2012 Ambassador Report Posted April 6, 2012 So does that mean you should be able to sew approx 35 yards in distance before running out of bobbin thread? In a perfect world...yes. But there are Variables..The more sewing you do the more the more you will learn. Quote Luke
Moderator Wizcrafts Posted April 6, 2012 Moderator Report Posted April 6, 2012 So does that mean you should be able to sew approx 35 yards in distance before running out of bobbin thread? No. It means you might have as much as 35 yards of thread wound on a bobbin. In actual use the bobbin winder might stop well before than amount has been loaded. Every stitch pulls the bobbin thread up into the leather, around the top thread in a knot, then back down. This takes up as much length as the actual stitches, if not more. So, if you are sewing a 4 foot long belt, that makes about 8 feet (2 sides) x 2 for the knots = ~16 feet of bobbin thread. This amount gets worse as the thickness increases, because the threads are pulled in even farther. Basically, considering that you lose thread each time you finish one piece and start another one, and that the actual amount of thread needed is twice the length being sewn (for each side), you might get 9 to 10 yards of two sided 8 ounce belts sewn per G bobbin load, using #69 thread. That would be cut in half for #138 thread. If the leather is thinner, you could sew farther on a bobbin load. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Wizcrafts Posted April 6, 2012 Moderator Report Posted April 6, 2012 Another thing I forgot to mention is that I got the 35 yards figure from a company selling pre-wound bobbin loads. The actually said 36 yards, but I allowed for loss from bobbin winder misalignment. Your bobbin loads could be higher or lower, depending on how perfectly the bobbin winder lays the threads into the bobbin core. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Moderator Art Posted April 6, 2012 Moderator Report Posted April 6, 2012 Count on 15 yards of sewing. I could tell you some tricks, but when they go wrong, they really go wrong. Figure on 15 yards and change bobbins before you get there. Remember, that changes with thread size, 1/2 that for 138. Don't let me get started on patchers, the bobbins are so small you have a hard time getting two jobs done. Art So does that mean you should be able to sew approx 35 yards in distance before running out of bobbin thread? Quote For heaven's sakes pilgrim, make yourself a strop!
