MADMAX22
Glueing fabric to leather?
Hey guys jsut wondering what is the best way to get some fabric glued to the flesh side of leather. I am making a wallet and would like to line the inside of the main piece with some cool fabric that I got.
Ive got some leather glue, not sure if that will hold it. I plan on lacing the edges but need something in the middle to hold it against the leather.
Thanks for your input.
i will be watching with interest as i make a mess everytime io try..
3M spray adhesive works pretty well
Contact adhesive. You can thin it down and brush it on.
singteck
OK thanks guys, I wasnt sure if the 3M stuff would harm the leather to terribly much. I know leather doesnt like petroleum products. I think Ill give that a try though as I use 3m for alot of other things.
Thanks
do a test sample first.
some glues will seep its way thru the fabric. im sure you dont want your paper money stuck to the lining?
LOL yeah,
I tested a piece of the fabric and glued it to itself with the leather glue from tandy. Seemed to work pretty good and took some force to pull it apart. It also didnt leach thru the fabric. Its just the bond wasnt as strong as I really would like. I picked up some upholstery fabric (feels allmost like suede on one side for couches and stuff, very nice looking and feel while being pretty strong) at Joann's to play with and figured I could try my hand at some wallets. Wanted to play with this because I got some really cool colors.
MADMAX22:
I've been using DAP/Weldwood nonflamable contact cement that I buy by the quart at Home Depot. I think it works much better than the Tandy contact cement. Cleans up with soap and water too. Don't know about using it on fabric, so test it first. It has worked well on thin suedes and lining leather for me.
I use fabri-tack - available at fabric stores for about 10 (in Canada). Bonds fabrics, lace, leather, wood & trim. Dries clear. Acid-free & washable.
Joy
I made a wallet and used 3M 77 to tack down the liner. No movement yet. Oh, and use a straight edge to lay down the fabric so you can avoid bubbles/wrinkles.
