Rockoboy Posted June 2, 2019 Report Posted June 2, 2019 From my experience, antique is made to stay in the tooled areas which would make them darker, so that is the opposite of what you want. If you used thinned paint (on a test piece, not your actual job), it would hopefully stay in the lower stamped areas, and be polished off the high spots. Maybe you need to polish with a cloth wrapped around a hard flat piece of glass-timber-bone folder etc (so it is only reaching the paint on the high spots) with some solvent on the cloth. Quote Kindest regards Brian "Whether you think you can or whether you think you can't, you are right" Henry Ford Machines: Singer 201p, Kennedy, Singer 31K20, Singer 66K16 ("boat anchor" condition), Protex TY8B Cylinder Arm (Consew 227r copy), Unbranded Walking Foot (Sailrite LSV-1 copy)
Members AJ2018 Posted April 16, 2021 Members Report Posted April 16, 2021 This is one of my antique art work for a project that I did. cheers . Another antique art work for a project cheers A.J Quote
Members LoopyLeathers Posted October 11, 2021 Members Report Posted October 11, 2021 On 4/19/2014 at 10:55 AM, SeekingPerfection said: right, I guess my question is how do you keep that natural look? are they blocking out those areas? I think that Yamatokobo is using a fiebings pro resist. in my experience that has been the best resist for keeping the leather as close to the natural colour as possible. he also may not even be using an antique? may just have a really good method for his tooling that is allowing him to achieve that beautiful natural deep bruising from his bevelling? that's my opinion at least. I love geeking out over his work. Quote
Members LoopyLeathers Posted October 11, 2021 Members Report Posted October 11, 2021 On 6/2/2019 at 10:54 AM, akatana said: I know that antiquing is usually done with a darker color than the piece is already dyed, but, I want to sort of reverse the effect. I want the tooled area to be lighter, preferably a silver or gold, to bring up the tooled design. I haven't found any antiquing gel/stain in either of those colors. I tried using acrylic paint, but it stuck to the untooled high areas, as well. My base was dyed, then two coats of Fiebing's Resolene. After that I painted the acrylic paint, let it stand for two minutes, then wiped it off. But it didn't wipe completely wipe off the high areas and when I tried wiping harder it pulled the paint out of the stamped areas. Was two minutes too long? Is acrylic paint the wrong thing to use? Any ideas? you can get a neutral coloured antique paste and mix your silvers or golds into that. providing you with a gold or silver antique paste. Voila. hope this helped. Quote
Members Grihm Posted June 11, 2022 Members Report Posted June 11, 2022 Long time ago, but always fun to mix a sealer and antique. I find that going over the piece with sealer 3 times or so worked best for me, then to build up the antique to the required tint without rubbing over the sealed parts too much. Overworking the area can cause tears and cause the colour to blend in under it. Quote
