Ambassador pete Posted April 25, 2012 Ambassador Report Posted April 25, 2012 here's their number. (440) 709-4980 If you email you'll likely get a response from Joyce. If you need to talk technical stuff, dimensions, ideas, etc..., call and talk to Jerry... he's an engineer. can you show the spiral template?!!!!!!!!!! pete
Members Sylvia Posted April 25, 2012 Author Members Report Posted April 25, 2012 (edited) can you show the spiral template?!!!!!!!!!! pete I'm having issues with swelling in my feet and legs at the moment so I can't take a pic for you. But if you go here http://www.blackrive...er-craft-tools/ There are a couple pictures of the set. You get the positive form and the negative forms with the set. in sizes 1", 2", 3" and 4" I played with mine for a while today. They work great! Well, hell... I'm sure they won't mind me posting their pictures here. Edited April 25, 2012 by Sylvia A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Chavez Posted April 26, 2012 Members Report Posted April 26, 2012 Thanks for sharing the link, Sylvia. How useful are the strap end templates? Has anyone used them?
Members Cyberthrasher Posted April 26, 2012 Members Report Posted April 26, 2012 Thanks for sharing the link, Sylvia. How useful are the strap end templates? Has anyone used them? I haven't used them since Sylvia just brought this to our attention the other day. But, I'm definitely going to be buying some. It's pretty much got all the strap sizes I would need between belts and cuff straps and I can tell by the pictures that all the holes are very well lined out. Since I don't have any strap punches, that part can easily take a lot of time to line up right (I'm really OCD), so I can see them saving me a lot of time. hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Sylvia Posted April 26, 2012 Author Members Report Posted April 26, 2012 Thanks for sharing the link, Sylvia. How useful are the strap end templates? Has anyone used them? Chavez. I'm probably the only one who has these templates since Black River just started making them. They are the perfect solution for someone that can't afford sets of expensive end punches and doesn't like the "multi-size" punch The set has 7 sizes for straps 3/8" wide up to 2"... one end is the English point... the other is the round point. The other set of strap templates have a "long point" I think most of us would use the English point. However, I have used the long point ones for making a tapered point on a strap end that was being sewn to another. That worked perfectly and refined the look of the attachment. ) To me the best part is they have holes to poke through to mark the places to punch for holes. ) It doesn't completely solve my personal issue with punching belt holes but it does speed up my process. The holes on the templates are every 1/2" (13mm) so 1/2" and 1" and up can be marked easily. The material it's made from is about 1/16" (2mm) thick so they will hold up well. I used the English point and the long point set on the guitar strap I just shipped. Easy peazy.... lay the template on the leather strap, mark the end with the stylus. follow the cut with your knife. I do intend to try cutting while holding the template on some scrap... I've not done that yet. I think clamping it to the table is my best bet to accomplish that... we'll see. I had previously made my own template but being cut by hand from aluminum, it wasn't perfect. This is a ton better. ) Be sure to ask them if they even ship to the UK Chavez.... I have no idea if they are willing to do that. (I bet they are though) S A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Moderator Art Posted April 26, 2012 Moderator Report Posted April 26, 2012 For those that do a lot of template work, contact Jeff Mosby at Grey Ghost Graphics. http://www.greyghostgraphics.com/ In addition to templates, he makes maker stamps or for that matter any stamps. He will also make you tap-offs and other stuff. Jeff is a premier guitar strap maker and does some really sought-after guitar neck inlay work. He stocks some templates for guitar straps, a complete set that contains everything, with instructions. Good guy and great artist. Art For heaven's sakes pilgrim, make yourself a strop!
Members Chavez Posted April 26, 2012 Members Report Posted April 26, 2012 (edited) Thanks Sylvia! I was thinking of cutting straight from the template (instead of transferring it onto leather with a pen/stylus. Let me know if it works=) I understand that the holes in the template only allow you to mark the center of the hole on the strap, so you have to center the hole yourself later? or can you just "punch through" the template? Oh, and pardon my lack of knowledge (i'm only a newbie here:)) , but what's the difference between an english end and a regular pointed end? As far as I know, english end is a bit longer and a bit sharper? Is there any practical difference in cutting & grooving them or is it just a matter of how they look ? Edited April 26, 2012 by Chavez
Members Sylvia Posted April 28, 2012 Author Members Report Posted April 28, 2012 Can you just "punch through" the template? Oh, and pardon my lack of knowledge (i'm only a newbie here:)) , but what's the difference between an english end and a regular pointed end? As far as I know, english end is a bit longer and a bit sharper? Is there any practical difference in cutting & grooving them or is it just a matter of how they look ? Hi Chavez: As they are now, you mark through the template, then center the punch. However, if you consistently use the same size belt punch I see no reason why Jerry couldn't adjust the template holes to accommodate the punch at least on the normal belt size ones. That is something you would want to talk to him about though. The "traditional" English point is shorter.... normally it is laid out with your wing dividers. On a 1 inch strap you measure up 1 inch from the end to be cut... then set your wind dividers to the width of the strap (1 inch) then drag the wing divider point of one side to the other side across the leather, pivoting on the other point. Reset and drag in the other direction. The result is a short point formed where the scribed arcs meet. The set that Black River has identified as an English point is not exactly correct. That's why I refer to it as a Long Point. You want the "strap end template set" if you are looking for the traditional pointed belt look. There is nothing wrong with the "engish point template set" excepting that it's points are too long. I've used mine a few times in various ways.... especially when I want to point off a strap that I want to sew to another strap. The longer more graceful curve works nicely for that. Practical difference? I think it's more of a preference... I prefer the points but some people prefer the round ends. I may be wrong but I think that the points would be easier to slide under a belt loop. S A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Sylvia Posted April 28, 2012 Author Members Report Posted April 28, 2012 For those that do a lot of template work, contact Jeff Mosby at Grey Ghost Graphics. http://www.greyghostgraphics.com/ Art Thank you, Art! I was aware of Grey Ghost Graphics... but my necessary frugal nature kept me from buying from him. I just do not have $95 for a belt template set... and holy smokes $145 for the guitar strap set is way way out of my budget. I do covet his petal lifters though... but again $100... out of my budget at least for now. <sigh> This is exactly why I like Black River.... everything they have thus far is under $20 a set. That is something that even us "church mouses" can afford. A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Chavez Posted April 28, 2012 Members Report Posted April 28, 2012 Thanks sylvia! Very interesting to learn about the english point . The prices seems great: had they been $5 higher, they would have attracted a $30 tax+fees for us UK buyers =)
