Members AndreasB Posted June 22, 2012 Members Report Posted June 22, 2012 Hi all, I got another question for you guys. I'd like to make some key fobs. I wanted to cut a figure 8 kind of piece of leather glue them together, stitch, dye... I tried to cut the leather a couple of times but it didn't really work out nice. Also it's not really possible to sand the edges on the now remaining circle nicely so I wanted to improve my cutting result in order to not need to sand. But like I said it didn't get much better. Any advice? I thought of getting a huge round punch an cut part of the circle away so I only have about 7/8 of the circle left and use this to punch my 8. Would that work? Thanks Andreas Quote
Members Jimbob Posted June 22, 2012 Members Report Posted June 22, 2012 Hi all, I got another question for you guys. I'd like to make some key fobs. I wanted to cut a figure 8 kind of piece of leather glue them together, stitch, dye... I tried to cut the leather a couple of times but it didn't really work out nice. Also it's not really possible to sand the edges on the now remaining circle nicely so I wanted to improve my cutting result in order to not need to sand. But like I said it didn't get much better. Any advice? I thought of getting a huge round punch an cut part of the circle away so I only have about 7/8 of the circle left and use this to punch my 8. Would that work? Thanks Andreas Andy, that would work.....but big costs and lots of trouble....wonder what kind of knife you use....? If you have a sharp knife you should be able to cut every shape you want just fine.....try a German "Schuster messer" with slide blade or fixed.....have it razor sharp!! And sanding the edges wil help to finish it of nicely, little burnishing and a bit wax makes it perfect....(Bandschleifer...?). Practice a bit and you will be cutting circels around yourself in not time....I use a Round knife ,,,( Halbmond Messer....) works fine for me but needs practice.. Also dann mal los, und immer feste ueben... Gruesse aus VA Aloha Jimbob Quote http://www.elfwood.com/~alien883 First it is just leather....then it is what-ever I can dream off...
Tree Reaper Posted June 22, 2012 Report Posted June 22, 2012 This is what I use to cut circles. http://www.misterart.com/tools/paper-trimmers/lion-ev-r-round-circle-cutter.html Quote
Members AndreasB Posted June 23, 2012 Author Members Report Posted June 23, 2012 Hi Jimbob, thanks for the advice. I tried cutting the circles with a really sharp cutter similar to the one you described and a rotary knife. The problem is when I try to cut the leather at once I need to apply a lot of force to the knife resulting in less control. And if I cut it in several runs the corner doesn't look nice. Also I tried it on my belt grinder but I would need a smaller wheel in order to get into the corners. Sanding by hand didn't work out great either. Tree Reaper, this seems to be a gizmo that might help. I need to find out if I can get a similar one in Germany Thanks guys. Quote
Contributing Member TwinOaks Posted June 23, 2012 Contributing Member Report Posted June 23, 2012 For leather up to about 8oz, I often use scissors. I have a pair that came in a set of garden tools than have large handles and a relatively small set of blades, resulting in good cutting leverage. They are smooth bladed, which I find works well on veg tan leather. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
LNLeather Posted June 23, 2012 Report Posted June 23, 2012 (edited) Hi Andreas How many of these do you want to make? If it was me, and I wanted to be making and selling a lot of these things, I'd figure out a way to make them good and fast... You might want to think about getting yourself a small shop press and buy a cutting die made to the specific shape you want. Some places make a standard key fob shape that might be less expensive to buy, or if you want a customized shape you might need to shop around for the best price. It might be you spend a couple of hundred bucks, but then you can make lots of perfect cuts. You get less waste and less frustration... You will have to decide if it is worth it. You can check this out for some basic info Plate Embossing And Die Cutting and - here's just a couple of places you can get cutting dies made If you are interested, I suggest emailing them and asking them about what you have in mind... Texas Custom Dies Tippmann Edited June 23, 2012 by LNLeather Quote ~Cheryl There are many things in life that will catch your eye, but only a few will catch your heart... pursue those...
