Members spurdude101 Posted October 26, 2012 Members Report Posted October 26, 2012 I'm trying to find out the specs on this LU2-400 machine. what kind of feed system, pressor foot lift clearence, what size thread and so forth. would this machine be good for chaps or rifle slings, guitar straps etc. thanks Quote
Contributing Member TwinOaks Posted October 26, 2012 Contributing Member Report Posted October 26, 2012 Initial google-fu searches make it look like it's a clone of a Consew 206. If you can, put a 'hold' on it until some of the sewing machine experts can chime in. If it is a clone of the 206 then it should handle the materials you listed just fine. Most of the clones have a clearance of ~1/2....maybe a little more, maybe a little less, but you should be fine sewing 1/4 inch or so of leather. Don't forget that you need to slow it down. Factory machines set up for high speed (2000+ spi) sound like " NYRRRRRRRRRRRRRRRRRR!"....and then you've sewn your hand to a strap. Please just take a word of advice on this....you do NOT want to pick even a single stitch out of your hand. Quote Mike DeLoach Esse Quam Videri (Be rather than Seem) "Don't learn the tricks of the trade.....Learn the trade." "Teach what you know......Learn what you don't." LEATHER ARTISAN'S DIGITAL GUILD on Facebook.
CowboyBob Posted October 27, 2012 Report Posted October 27, 2012 Mike is real close,although it's more like a Juki 563 or Consew 255 w/a vertical bobbin, around 1/2" foot lift should sew 20 oz of leather,use up to #138 thread & it takes very common pressure feet just like the Juki & Consews. HTH Bob Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members gottaknow Posted November 2, 2012 Members Report Posted November 2, 2012 As a whole, Mitsubishi's are decent machines. I just rebuilt a 15 year old 2 needle machine with all the bells and whistles and it's performing well. Their hooks need to be kept oiled, above what the hook oiler provides. (At slow speeds, this is probably a non-issue.) If not, you'll get some binding on the basket (where the bobbin goes) which can break thread and cause other issues. Best check on any machine with verticle hooks is to remove the bobbin and move the basket all around inside the hook. If there's a lot of play, stay away from it. Other than that, they're pretty decent machines. I have about 15 various models and ages of Mitsubishi's and they all still perform well. Regards, Eric Quote
