LNLeather Posted January 6, 2013 Report Posted January 6, 2013 I think those look great! What o you mean by petals there is the pod, and the leaves, and the thistle. I have an emboss plate made by duckcreektraders and here is what that look like the top 'thistle' is more like lines (or a brush) Hope this helps Quote ~Cheryl There are many things in life that will catch your eye, but only a few will catch your heart... pursue those...
Members Chavez Posted January 6, 2013 Author Members Report Posted January 6, 2013 by the petals I mean the top. I thought about leaving it blank and putting a lot of decorative lines with a swivel knife but not sure if it's going to look good and whether I can get enough consistency on them =/ I either end up with the "top" that's not detailed enough or just doesn't look natural. Either way it looks out of place when compared to the rest of the carving. I'll try a few more ideas tomorrow =/ Leaf liner didn't work, camo didn't work, Quote
Members rosiart Posted January 6, 2013 Members Report Posted January 6, 2013 From looking at your trial pieces, I think they bother you as they seem too substantial on the top part. The thistle is sort of wispy on top. I wonder if you used a hair blade along with decorative cuts, if you could get that effect. Quote Rosemary RosiArt's Blog
LNLeather Posted January 6, 2013 Report Posted January 6, 2013 btw - not sure you want to put acorns on your Scottish thistle... ? Quote ~Cheryl There are many things in life that will catch your eye, but only a few will catch your heart... pursue those...
Northmount Posted January 6, 2013 Report Posted January 6, 2013 I second using a hair blade. Try the fine and coarse to see which looks the best. I'm tending to the fine blade, since the thistle is wispy. Tom Quote
Members Sylvia Posted January 6, 2013 Members Report Posted January 6, 2013 When I look at your trial pieces, I feel like the flower part... the purple part is over worked. The beveling doesn't enhance the fine detail, but rather makes it look somewhat like a scallop edged spoon. Sometimes LESS is more. I think if you use a hair blade (or several pointy crafters xacto blades taped together) and make deft long cuts so that it looks a lot like hair... and then only do a little beveling around the entire flower (purple) part and the bulbous area, you will be much happier with the results. Quote A teacher pointed at me with a ruler and said "At the end of this ruler is an idiot." I got detention when I asked "Which end?"
Members Chavez Posted January 7, 2013 Author Members Report Posted January 7, 2013 Thanks guys, I'll try it this week. Don't have any good quality hair blades but let's see if the cheap one works... Quote
