mistyped - I think you know what I mean, don´t you?
37mm - 120mm is approx 1:3 and 37mm - 160mm is about approx 1:4 reduction
Edited by Constabulary
The pulleys I make myself are usually 50mm-->215mm or so, for a bit over 4:1. You will want to use a 10mm (9.7mm?) wide belt with very small pulleys, since they flex much more easily. Stay with very good quality belts, since the uneven splices on the cheap ones can cause a horrible *thump thump* that I promise you will hate.
-DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
Thank you, guys! Its easy for me to make the speed reducer, i think there is no problem if i use aluminum, right?
Yes, i have to use its a 10 mm belt and i will buy some good quality belts, don`t worry! :)
  • 4 years later...
On 1/22/2013 at 7:39 PM, Northmount said:
Here are a couple pictures.
post-16698-0-75332100-1358901239_thumb.j
post-16698-0-83426900-1358901271_thumb.j
The slot in the table had to be lengthened to use the same belt as had been used for the motor. The pillowblock bearings are for a furnace fan that typically runs 900 RPM so I'm not worried about them lasting. Had to shift the motor over a bit, and play with the tensioning adjustments, finally decided to keep it real simple and use a bungee cord for the motor belt tension. For the belt to the head, just slide the jackshaft bracket down to adjust, then tighten the clamp to the leg. Since the leg material is on the light side, there is a block inside to keep the leg from being squashed.
Tom
Tom (or anyone else who might know):
Where did you find the sheaves for this? I might want to do a jackshaft speed reducer for my Adler 67 / Consew 550, but I'm not sure where to find sheaves at a decent price. Surplus Center, maybe? Ebay? I'd try Grainger or MSC but suspect they're $$$$$$$$ there (like most things)...
Also, what kind of reduction are we generally looking for here? Something like 3-to-1 I'm guessing (3-1/2" to 10-1/2" for examaple)?
Thanks in advance for any help.
W.
Edited by Wellington
Adler 67 GK373  •  Pfaff 130-6  •  Singer 201k-3
Also, what kind of reduction are we generally looking for here? Something like 3-to-1 I'm guessing (3-1/2" to 10-1/2" for example)?
W.
My junk box has a number of sheaves and other odds and ends in it from other projects, or stuff I have salvaged.  Only thing I had to purchase was the bearings.
Chances are, you should be able to get sheaves and pillow block bearings from Harbor Freight, or from some of the local hardware or big box stores.
Tom
Thank you, sir! On second glance, I'm guessing your ratio is closer to 4:1 on your pulleys.
Is there anything, in hindsight, that you would do differently or improve with your setup? I will probably do something quite like yours. (Still getting my Adler 67 up and running at this point...)
Thanks again.
Thanks again.
On an  flatbed machine that sets in a table it is best to keep the reducer back by the motor so you can tilt the head back easily,the cylinder arm machine Northmount shows in his pic sets on top of the table & the style he made (which looks great) will work best on that type of machine(which is what we use too) you need to make one that looks like our box style so you can tilt the machine back as needed.
So we have the box style(for flatbed machines) on the left & SR2 (for cylinder arms) on the right in the pic.
Hope this helps you.
Bob Kovar
Toledo Industrial Sewing Machine Sales Ltd.
3631 Marine Rd
Toledo,Ohio 43609
1-866-362-7397
Nobody has mentioned installing a larger pulley to replace the hand wheel. I replaced mine with a 170mm pulley and it made a considerable difference before buying a servo motor. Speedwise, I'm now where I want to be apart from a sudden start which I think I can alleviate with the treadle position.
A 6" and a 3" pulley, so 2:1, plus the 3:1 in the geared servo.
I like the way the speed reducers Cowboy Bob has.  I may someday rebuild mine like the box that sits between the motor and the table.  Just have too many other projects to get done first!
As long as the pulley that drives your machine sits behind the centre line of the machine pulley, you can tilt the head back.  With my reducer in front of the leg, I can't tilt the head back without loosening or removing the belt.  Lesson learned! If I could, it would make it easier to tension the machine belt.
Tom
Thank you, CowboyBob and Northmount and Toxo. This is all great information, particularly those photos.  I appreciate your help.
I'm figuring out all my sheave sizes to get speed reduction right and had a question for you folks, since I don't want to reduce the gear ratio too much nor not enough.
This Adler 67-GK373 will be used for upholstery, some heavy textile sewing, and maybe 15% leather work, most of it lightweight.
Rig has a Consew 550 motor w/ max speed of 3450. Consew claims it's 3/4 hp (though I'm not sure how you get that from 550W).
According to mfgr, this Adler 67 has max speed of 2000 spm, but I can't imagine ever wanting to go over 1000 spm. So I'm considering gearing my reduction jackshaft to give 1000 rpm at the machine when the Consew is WOT at 3450.
Does that sound reasonable to you folks? I'm accustomed to fairly slow machines (other machines are a Singer 201-k3 and a Pfaff 130-6) so even 1000 spm is cooking with acetylene, as far as I'm concerned.
TIA for any insights.
W.
ETA: For what it's worth, right now, drive sheave is 3.5" and driven is 4" so I would need a 3:1 reduction from that to get to my current target. Will that give me enough oomph at low speed for the occasional heavy leather job, or should I reduce it further?
I personally use a servo motor that lets me limit the top speed with a knob. When I sew small areas and vegetable tanned leather I limit the speed to a couple hundred rpm and sew very slowly; sometimes 1 stitch per second. When I sew upholstery leather, banners and long items, I crank it up to maximum speed and sew as fast as the machine wants to go (about 2000 spm). In upholstery, time is usually money. Just make sure you oil the machine well before running it flat out.
Posted IMHO, by Wiz
Thanks for the information, Wizcrafts. Now you've got me thinking. I may be able to get away with no jackshaft – just replace my 3.5" driving sheave with a 2.3" sheave, which at 3450 with a 4" driven sheave should give 2000 rpm at the machine head. (Assuming my math is right.)  So if I wanted to get, say, 60 spm at the machine, I could dial the motor down to about 100 rpm ... do you think 100 rpm on a Consew 550 will give me the punch I need for say 1/8" to 3/16" leather at 1 stitch per second without too much slippage at that 2.3" diameter driving sheave?
I'm just a hobbyist/beginner, really, at this point, so I don't really care about going super fast ... more concerned about having good torque at low spm speeds so I don't have to horse it with the handwheel...or dial up the speed dial and then have it run away...on this motor, at least, there's seems to be about 1 second's worth of angle difference on the speed adjustment knob between "manageable" and "holy cow, LOOKOUT!" and the remaining 95% of the adjustment dial is useless. (At current gear ratio, max motor speed should give 3000 spm at the head, whereas Adler recommends max of 2000 spm for that machine.)
Sorry for the dumb newbie questions, and thanks again for your help.
Wellington, in round figures 550w is 3/4hp.
Thanks, Dikman.
Before I go and fab up a jackshaft arrangement, I'm going to try a smaller drive pulley (2.25" dia instead of 3.15" which should get me a max speed of 2000 spm at the machine head) and mount a longer lever arm on the servo motor's throttle arm (and/or maybe weld a shorter lever linkage arm to the pedal plate) and see where that gets me.
May also investigate trying this fix addressing the optical sensor in (some) servo motors:
Does anyone know whether my Consew Premiere 550 uses such an optical controller? Its symptoms sure seem to match those discussed in the video.
Thanks again. I'll report back with my findings for the forum.
W
As toxo mentioned if you replace the handwheel with a larger pulley that, coupled with a smaller motor pulley, will give you the equivalent of fitting a speed reducer. And it's simpler. I've done it on several machines.
Thanks again, Dikman. I might try that. I'd assumed that the pulley and handwheel were one unit that couldn't be separated. Even if that's the case, I guess I could just use the pulley itself as a handwheel, but if it's possible, I'd prefer to take out the existing pulley, replace it with a larger pulley, and then replace the original handwheel. Walking foot hot rodding! :Lighten:
Sorry mate, every handwheel I've seen has been permanently attached to the pulley! The shaft won't be long enough to attach another pulley as well as the handwheel.
Here's what I came up with. I tripled the effective length of the "throttle lever" on the servo motor by attaching a ~ 10" piece of aluminum tubing to it (tubing nearly flattened with a vise at ends before drilling).
By lengthening this throttle lever, and putting a smaller drive sheave on the motor, and jamming a tennis ball (to act as a compression spring) under the back of the throttle pedal, I can set the motor speed to full speed, and still feather it to go slow with my foot. And if I want "full speed," I can mash down on the pedal and get it, without changing the dial position on the motor. (The other half of the answer, I think, is refining the fine motor skills in my leg and foot. I've always preferred knee throttle levers to work around this clumsiness. I hope I don't get turned around switching back and forth between machines but really look forward to having a knee presser lifter, and will probably copy it to retro-fit a knee presser lifter to my Pfaff 130...some of them came from the factory that way, but trying to find the lever part is a losing propositon.)
Don't know whether this kludge will have the torque/punch for heavy leather, but it should work for my purposes sewing light leather and heavy fabrics, I think.
Thanks again for everyone's help. This is a great website...it seems that every time I have another question about my new walking foot machine, Google leads me here (for example, I just found Wizcraft's simple solution for stopping bobbins from slipping on the bobbin winder shaft...thank you Wizcrafts!).
W.
I have found that if you have your belt tension to tight, it will make it stiff to move the peddle.
I slacken the belt so it is just tight enough to turn the pulley without slipping, will help. A new grippy belt works a lot better then an old hard belt.
Bert.
