lightingale Report post Posted January 27, 2013 I've been making coasters as promotional items using a large (2 x 1.5 inch) maker's stamp in the center. Using a maul is problematic not only for the lack of depth of the large stamp; I also get shadow impressions from smacking it multiple times with the maul. I looked up the imprinting machine on Tandy, but I'm not willing to drop $450-$500 on a machine whose effects I believe I can duplicate with things from the garage and hardware store. I admit I'm not the kind of girl who has spent a lot of time in the garage, so I'm looking for your suggestions as to how I can make an imprinting machine on the cheap. Doesn't need to be fancy... I just hope to stop wasting coaster-shaped pieces of leather on shadowy multi-impressions of my maker's stamp :-) Thanks Quote Share this post Link to post Share on other sites
Cyberthrasher Report post Posted January 27, 2013 You're just wanting to use your maker's stamp, right? Just get a shop press (pretty cheap at Harbor Freight), or even use a bench vise since the work you're doing should be small enough to fit. Quote Share this post Link to post Share on other sites
Dwight Report post Posted January 27, 2013 (edited) This can be made out of a couple of 2 x 4's a couple bolts, and if you have any kind of shop at all, . . . about a half hour of work. Basically, . . . the brown leather is placed on the mat, . . . the red imprint is made by pushing down on the handle. It wouldn't take too long to figure out about how much pressure, . . . and once you get that "touch", . . . they should all be pretty much uniform. Approximate cost: $5 May God bless, Dwight Edited January 27, 2013 by Dwight Quote Share this post Link to post Share on other sites
WinterBear Report post Posted January 27, 2013 I use a couple of clamps and some lino blocks I had laying around to imprint letterpress blocks. http://leatherworker.net/forum/index.php?app=galleryℑ=18247 The pics in my gallery are mostly of the small letterpress cuts, but I've used the same method on letterpress blocks up to 2 inches by 4 inches with good results. But I like Dwight's press better, as it will allow for a more even pressure and would not obscure what you are trying to stamp. (Dwight, I'm gonna steal your idea for Box Scouts/Cub Scouts, if you don't mind. The younger ones don't have enough upper arm strength to give firm blows with a maul for the 3-D stamps they love so much). Quote Share this post Link to post Share on other sites
Northmount Report post Posted January 28, 2013 Order a 1 ton arbor press from Busybee. Closest store to you is Ottawa, but you can order online. http://www.busybeetools.com/categories/Metalworking/Arbor-Press/ Using a maul (or mallet) on large stamps results in a bounce that gives double impressions. You can get a dead blow hammer that doesn't bounce. Check Busybee or other tool stores near you. Tom Quote Share this post Link to post Share on other sites
Dwight Report post Posted January 28, 2013 I use a couple of clamps and some lino blocks I had laying around to imprint letterpress blocks. http://leatherworker...eryℑ=18247 The pics in my gallery are mostly of the small letterpress cuts, but I've used the same method on letterpress blocks up to 2 inches by 4 inches with good results. But I like Dwight's press better, as it will allow for a more even pressure and would not obscure what you are trying to stamp. (Dwight, I'm gonna steal your idea for Box Scouts/Cub Scouts, if you don't mind. The younger ones don't have enough upper arm strength to give firm blows with a maul for the 3-D stamps they love so much). Just holler if you need a more detailed diagram. May God bless, Dwight Quote Share this post Link to post Share on other sites
EmbossingDieCompany Report post Posted January 28, 2013 I use both a table top vice (that I bought at Harbor Freight for $20) or a 1 ton arbor press (currently on sale at Harbor Freight until the end of the month for $38 with coupon). Coasters should be no problem whatsoever with either one. Here are pictures of some larger plates I did with the vice. Quote Share this post Link to post Share on other sites
