Whisky bent, hell bound
A belt for a friend I finished this weekend. I am a little unhappy with how much it lightened when I put the TanKote on it. I haven't used it too many times, is this lightning of the dye something I should expect? I mean it changed 10 shades lighter. Comments/critiques welcomed.
post-28630-0-68862300-1359375832_thumb.j
post-28630-0-81041700-1359375848_thumb.j
post-28630-0-07324600-1359375864_thumb.j
Was the stain you used dry when you applied the tan kote? I've had some lightening but not ten shades.
www.smithleatherworks.com
PLEASE LIKE MY FACEBOOK PAGE - CLICK HERE
I've learned to wait a minimum of 24 hours before applying finishes. The Tandy ecoflow finishes seem to rub right off unless they have plenty of time to set up.
I had waited around half a workday, should have just let it hang to dry another half a day. 10 shades might be an over exaggeration but it was substantial. I'll have to do some test dyes on scraps and see what the look like after a full day of drying.
  • 2 weeks later...
Hi there, how did you apply the text and design ? it looks burnt on which is very interesting.
Did you consider a border along the edge to set it all off.
Is there any reason you chose to rivet instead of stitch ?
What sort of leather did you use? What sort of buckle?
Not dead, can't quit.
  • 1 month later...
It's all tandy stuff. The belt blank, buckle. I used Chicago screws (I think that's what they're called) instead of sewing because I don't like the pre-installed riveted snaps. The Maker's Mark logo was just burnished in with my stylus. A major PITA that I won't be doing anytime soon. Text was traced on and Icut then stamped in the letters instead of outside, just wanted to try something I hadn't done before.
  • 2 weeks later...
That's interesting thanks :-)
