Members Blake428 Posted March 4, 2013 Members Report Posted March 4, 2013 I'm looking at purchasing a skiving machine and wanted to know if anyone is familiar with the Consew DCS-S3. Is this a good machine or should a spend the extra money and go with a cobra. I will be skiving 10oz leather max, but mostly 4-5 oz oil tanned. Quote
Members Greystone Posted March 4, 2013 Members Report Posted March 4, 2013 I just got a cobra NP 4 and its the bomb,,, well made ,easy assembly, set up,,FOR LEATHER and now its my learning curve which will need adjustment Talk to Steve,,,tell him what you want and how you wanted it set up.Give samples or pics and they will get it right from the "get go" I also looked at the consew and figured a setup and tested machine is well worth a few $hundred$ more, money saved on the learning curve and test material,, Quote www.facebook.com/pages/Greystone-Leather www.etsy.com/shop/GREYSTONELEATHER
Moderator Wizcrafts Posted March 4, 2013 Moderator Report Posted March 4, 2013 10 ounces is considered lightweight when it comes to skivers. I used to have two skivers. One was a Fortuna, with a stone drive, which was best suited to shoe upper or garment leather. The other had a serrated steel wheel and worked best on veg-tan and sole leather. That machine tended to eat chrome tanned leather, as it skived it. I got rid of both machines a long time ago. The modern top and bottom drive units can handle both ends of the skiving spectrum. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Blake428 Posted March 4, 2013 Author Members Report Posted March 4, 2013 I would like to get the cobra np4 $1900 but I found a Consew DSC-S3 for $950 that's a pretty significant price difference. Would it really be worth spending the extra for the cobra? Quote
Moderator Wizcrafts Posted March 4, 2013 Moderator Report Posted March 4, 2013 You'll appreciate the difference you paid for the Cobra skiver when you need help with some problems that develop, or parts that wear out or get damaged from misuse. Unless you are prepared to fix parts yourself, including the band blade, buy the new machine from Steve. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Blake428 Posted March 4, 2013 Author Members Report Posted March 4, 2013 Thank you for the input. I have a Cobra class 4 and love it. Steve is a great guy and a big help when it comes to his machines. Ill save up and go for the Cobra. Quote
Members Greystone Posted March 4, 2013 Members Report Posted March 4, 2013 I would like to get the cobra np4 $1900 but I found a Consew DSC-S3 for $950 that's a pretty significant price difference. Would it really be worth spending the extra for the cobra? cobra np4 is $1200 bottom feed ,same machine as consew dcs-s3 ,,,,,,,,,,,,cobra np 10 $1900 top n bottom feed Quote www.facebook.com/pages/Greystone-Leather www.etsy.com/shop/GREYSTONELEATHER
Members Blake428 Posted March 4, 2013 Author Members Report Posted March 4, 2013 My fault, so many part numbers. I was looking at the 10 but ill look at the 4. What is the benefit to a top and bottom feed opposed to just a bottom feed? Quote
Moderator Wizcrafts Posted March 4, 2013 Moderator Report Posted March 4, 2013 Top feed assists the feeding of sticky materials, like some chrome tanned leathers. Normally, with bottom feed only the leather could drag under the presser "foot" that is on top. That foot determines the thickness to be skived. With a driven top foot, sticky or extra dense leather gets moved through no matter what. Expect a medium learning curve with a first time skiver. It takes a lot of practice to set them up for different leathers and thicknesses/angles of cut. Properly adjusted, they can do lap skives. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Techsew 2700, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Contributing Member Ferg Posted March 4, 2013 Contributing Member Report Posted March 4, 2013 Get a bottom and top feed machine. I can put any thickness of any type leather through mine without problems. Information on adjustment of all the different knobs etc. are practically unavailable. I don't remember if Steve sells his skivers with a clutch or servo motor but I am sure he would sell you which ever you want. My machine had a clutch motor on it when I bought it. Just too doggone fast for me to handle fine, thin leather. Swapped the clutch for a digital servo, best thing I ever done. I have taken some of my machine apart, have to see how it works. Have tried to do every adjustment imaginable to see what effect it has on different leathers. Yes, I have wasted mucho leather, wait, it wasn't really wasted was it? I am getting pretty good with it finally. Most all the machines, no matter what the name plate says , are made pretty much the same. They all need daily oiling in spots you probably would never see if you didn't have some instructions. Information coming with the machines is lacking for the most part. Anyone buying one of these machines.....If I can be of any help just let me know. ferg Quote
Contributing Member Ferg Posted March 4, 2013 Contributing Member Report Posted March 4, 2013 This may be considered "High-Jacking" this thread but I believe some information I have gathered may be useful to some folks buying one of these machines. I have read numerous articles/tutorials, watched about every video I could find, most several times, still did not have the finite information everyone needs to properly adjust these machines. My machine has the grooved steel feed roller on the bottom. You have probably noticed the feed wheel has the same radius the Bell Knife has. Vertical adjustment for the feed roller is to the rear of left end while the angle of the feed roller is adjusted by threaded adjuster to the front on left end. Adjust the angle so the feed roller fits the curve of the knife. You can adjust the proximity of the roller to the knife with the rear adjuster. Use a couple pieces of copy paper about 1/2" wide to slide between the roller and the knife blade. one toward the back, one to the front of the feed roller. Adjust the up and down until the paper strips just slide between knife and roller. This is almost perfect adjustment for chrome tanned leather that is fairly soft from 1.5oz. to 4oz. Lining leather for instance or Kangaroo leather. The top roller I use most often is tapered from back to front. You will learn quickly that adjustment of where this roller meets the bell knife determines how wide the skive will be. With this leather I bring the top roller close enough to the knife that you can only slide that piece of copy paper between them. Don't allow the roller to rest on the knife, you might distort the edge. There is a spring on a hook mechanism to the left rear of the machine. This adjusts the amount of pressure required for the feed roller to hold the leather being skived, against the bell knife. Light weight leather I place this in the second notch. Thicker/harder leather I may pull the spring all the way out to last notch. Also: Some belt leathers, among others, are very hard temper. You will need to lower the bottom feed roller slightly to allow leather to go through the knife. There are small oiling holes on the shaft of the lower roller, oil them frequently. they are a little difficult to access, be creative. That is a few items that may help some of you anyway. Let me know if I can be of further help. ferg Quote
Trox Posted March 4, 2013 Report Posted March 4, 2013 Hi Blake, the way I see this. A bell knife skiver is a must when you work with upholstery type of leather, when it comes to heavy leather you can always use a knife. Of course you can do this on the soft leather too. However, its a lot of work and not easy to get a nice results. I have a Italian bottom feed with a three motor setup, a full speed knife and small servo for the speed roll. The third motor is for the exhaust fan. If I use my steel roller on it I can skive heavy weg tan leather with good result, 4 to 5 mm thick (12 oz) is no problem. Like I mention above, I use mine mostly for soft leather. A bottom feed will skive that stuff just fine. It has to be a big skiving job before I change to a steel roller and adjust it for heavy leather. Most of the time it easier to just skive it by hand. However,If you are going to use it for mostly heavy leather, a top and bottom feed is your best choice. I see both the choices have a one motor setup, thats means the knife and roller speed is controlled by the same pedal. It must be possible to attach two motors on these skivers too, it is a advantage to have the knife turning at full speed and use a small servo for the feed roller alone. I think it should be possible to do so with any Fortuna style skiving machine, it only a matter of setting it up with the right type of V belts. To propel the feed roll a small inexpensive home sewing machine servo at 55 to 85 W will do the trick. Then you can use a normal industrial AC motor for the bell knife, let it run on full speed all the time. I do not know if this is possible with this kind of skiving machine, I have seen the Fortuna bottom feed skiver (same as Cobra NP4) set up like this. (My machine is different, it has a inbuilt small servo for the roller, see pic.) If anybody has this style of machine with a two motor setup, please let us know. About where to buy it. It was a huge price difference, normally the Consew DCS-S3 costs more than the Cobra NP4. They are sold to $ 1345,- other places. Remember what you pay for, If you buy from Steve at Cobra you will get support. If you are new to skiving machines you will for sure need it. Good luck. Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members tribo korokan Posted March 13, 2015 Members Report Posted March 13, 2015 I have a Consew Skiving machine DCS-S4 and very frustrated with it.I bought it to skive 2=3 oz. and 3-4 oz. of leather and it always eat up my work. Was trying to make leather wallet with folded edge. I always end up skiving it manually. Saw the fortuna machine just do it so easy on you tube. Is there a trick to make this thing work. attach photo: Quote
Members Andrew Chee Posted March 14, 2015 Members Report Posted March 14, 2015 On thing to try is to move the bell knife closer to the presser foot. When you are skiving thin leathers that helps. If there is too much of a gap between the blade and the roller the leather can press down and get eaten up. For thicker leathers, move the blade away so there's more room. See if that helps. Andrew Quote
Members tribo korokan Posted March 14, 2015 Members Report Posted March 14, 2015 I move it close to the presser foot. This is the result and I dont feel that it is eating much of the 2 oz leather like what happened before. I need to do more practice t get it right. And I cant seed to make my bell knife sharp enough. It does seem to be working for me now. Great advice Andrew. Quote
Members DDahl Posted March 14, 2015 Members Report Posted March 14, 2015 There is a neat trick to skiving thin leather that I discovered. Go down to your home supply store (home of de pot) and buy a 1" wide roll of Scotch blue delicate surface painters tape (#2080). Now attach a strip to the top edge (finished side) of the leather you want to skive. Trim the ends off close to the end of the leather piece. The tape is very slippery on top and solves and sticking problems nicely. The tape firms up the leather a bit and makes it slide through the skiver like butter. I routinely skive chrome tan leather to a thickness of 0.015" for wallets without the skiver ever eating up the leather. be sure to remove the tape right after you skive it. This with a correctly adjusted skiver (as describe above) will change your world with thin sticky leathers. Dave Quote
Trox Posted March 14, 2015 Report Posted March 14, 2015 Hi Tribo, I always finishing sharpening the bell knife with the burr removing tool and the grind wheel together; and moving them both away from the knife in the exact same moment. Then I stop the machine to feel with my fingers for burr`s. If you do one side after the other, it will likely form a burr on one side of the knife. The knife must be perfect to skive well, especially on thin delicate leathers. I see that my bell knife has a longer (wider) edge than yours. Perhaps you have to dress your grind stone (with the dresser tool) and then grind a longer edge on your knife (be careful not to overheat). I do not know if that helps or not, but it is important in all other types of skiving; to have the right angle on the skiving knife (I believe it does matter here too). On difficult thin leather you can use the help of some blue color (painters) masking tape. Place it on the grain side of the leather, to make sure it does not curl up when skiving. The blue color tape is easily removed afterwards. Adjust your feed wheel to have the same distance from the knife all over its curve/radius. You can use the aids of paper strips when adjusting it. Place them between the feed wheel and knife, bring the wheel closer to the knife and when you pull out the paper strips you will feel the Resistance they give. This way you can adjust the feed wheel distance to be equal all over the knives curve. Then bring the feed wheel back out to the recommended distance from the knife. I use the same distance for all weights of upholstery leather, for thicker leather you can back of the feed wheel spring pressure a bit. These skiving machines has a step learning curve,but keep practicing and you will get it right. Good luck Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Members tribo korokan Posted March 14, 2015 Members Report Posted March 14, 2015 This is interesting. I am gonna try this one. Quote
Members tribo korokan Posted March 15, 2015 Members Report Posted March 15, 2015 The burr remover I presume is the small grinding stick . I notice that I pull hard to get my piece across to get skive.That means my bell knife is not sharp? How many seconds you need to run the grinding wheel to make it sharp.? I did not try the blue tape yet cause I am still learning to sharpen this bell knife . Quite silly . I never thought this is such a big challenge on my part.Thanks again for the advice. Quote
Contributing Member Ferg Posted March 15, 2015 Contributing Member Report Posted March 15, 2015 (edited) Two things I notice. You appear to be grinding your knife on a very small portion of the edge. Check the grinding wheel to see if it is level across the grinding face. If not you need to use the "dresser" to make it flat. The grinding wheel should touch the entire angle of the original grind of the bell knife, yours seems to be messed up. Also, your machine has a "stone drive wheel". They can be a problem if not kept very clean. This may not be causing any of your problems now but it can in the future. The paper method of adjusting the drive wheel to the knife is an easy way to get a nice thin skive but it can create a problem also. You would need a number of different thickness of paper to set different skives. I take a test piece of leather I am going to use for a project, run it through the skiver. If it is the skive you wish no adjustment of the drive wheel and the top hold down is necessary. The distance from drive wheel to the bell knife should be the thickness of the skived leather you wish when it is finished. Distance between the top hold down and drive wheel should be set to the thickness of the "Un-skived" leather. It is not unusual to have to fiddle a little bit with the settings for some thin or thick leathers. Gloss finished leathers will feed differently than raw or dull finishes. Hope this helps a little. ferg Edited March 15, 2015 by 50 years leather Quote
Members tribo korokan Posted March 16, 2015 Members Report Posted March 16, 2015 "The grinding wheel should touch the entire angle of the original grind of the bell knife, yours seems to be messed up" I need to move the bell knife forward to make the entire angle be grind. The grinder is only hitting the tip of the bell knife. Thanks you all for all the great suggestions. Quote
Trox Posted March 16, 2015 Report Posted March 16, 2015 HI Tribo, your feed wheel should feed the material true. You need to go true the adjustment to find the zero position on the feed wheel (parallel to the knife) then work on you knife edge. You should not have to run grind stone very long, but if your edge is wrong and has burr`s. Then you must use the time it takes to make i good again. And Like Ferg says (that I wrote too) use the dresser tool on your grind stone; it should sharpen the entire edge. Well, the paper adjustment method is quit simple and is to make your feed wheel parallel to the knife. Its not a thickness adjustment! you must bring you feed wheel out again to the proper (desired) distance from the knife. Like I wrote in my post. I adjust the feed wheel distance from thin to thick leather, but leave as is for most upholstery weight of leather. Then I only have do the adjustment on the foot height. And of course; I too have to do test runs on the same material before doing the actual skiving job. Tribo, is your machine a constant speed knife or a variable speed one? Mine has a constant speed knife and variable peed feed wheel of course. If you have the first option, perhaps it will skive better on a higher speed. I thinks its possible to change the knife speed relative to the feed wheel, change the belt to another pulley (inside the machine). I do not know because thats never been an issue on my machine. Good luck Tor Quote Tor Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
