Alright, so i bought one of these Loop Clamps
because i thought i knew how they are used. Turns out.....
.... i don't :)
Can anyone explain how to use this thing correctly?
Thanks in advance
Cheers
Schpacko
It fits inside the jaws of your stitching clam with the circular part downwards and the horizontal 'wings' resting on the top edge of the jaws. The loop is inserted in the vertical metal jaws.
Hope the not very good diagram helps.
Thats a very good answer, short and well explained.
Here is its wooden counterpart.
Tor
post-10237-0-24210600-1365783107_thumb.j
Tor
Workshop machines: TSC 441 clone/Efka DC1550, Dürkopp-Adler 267-373/Efka DC1600, Pfaff 345-H3/Cobra 600W, Singer 29K-72, Sandt 8 Ton clicking machine, Alpha SM skiving unit, Fortuna 620 band knife splitting machine. Old Irons: Adler 5-27, Adler 30-15, Singer 236W-100
Slight piggyback: what advantages does the metal type have over the wooden one, or vice versa? I can get either for roughly the same price.
I`d check which fits your clams the best first as my metal loop clamps do not fit my stitching pony which I use at shows but fit my clams at home because of the rounded shape. The best loop clamps I have used were made from sprung steel bent back on itself around a round bar and had small stops fastened on the outside to stop them slipping down the clamps (like the notches on the pictured wooden clamps) one day I will get some made but it`s not at the top of the to do list yet.
The wooden clamp is cheaper. Its a bit to stiff , I suppose it softens up a bit with more use. Or else I have to trim of abit wood to make it softer. I have to admit I use a lot of of brass loop staples ( and regular staples on hidden places), not often I take the time to sew my loops.
Tor
Tor
I use my screw crease to stitch loops hope this has not confused this topic.
Have noticed some cheaper metal loop clams can bend out of shape.
Kind regards JCUK
  • 2 years later...
Does anybody where these can be found nowadays?
I remember Bowstock offering them some time ago, but I can't find them now, when I actually want it of course.
Edited by simontuntelder
Hi Simon, I think Abbey still have them both. My wooden one has till not soften up, but I do not use it that much. I mostly use a special brass loop staples instead of sewing. If the paint comes off the metal clamp it will stain the leather. You could modify the wooden cheaper clamp, by removing some excess material to soften it up a bit. It's excellent material in it.
Tor
Thanks, Tor.
I spent hours browsing through Abbey the other day, as I'm placing a big order with them soon, but I didn't see them, but their website is a bit weird, so I'm sure it's there and I'll go in and add the steel and wooden clam to the cart.
