Members CADBURYS Posted April 15, 2013 Members Report Posted April 15, 2013 im having trouble sharpening my edge beveler does anyone have any tips please Quote rough & ready ,& busy chasing the grandkids
Members ReneeCanady Posted April 15, 2013 Members Report Posted April 15, 2013 I haven't tried it yet, but this was a question I had a while back as well. I got this response, sounds good Renee, if you go to a local hardware store, take your beveler. Find the bin where they sell wooden dowels, and try your beveler on the smaller ones (around 1/8th of an inch) until you find the one that matches the curve in your beveler. You then need to go to a auto parts store, tell them you want a very small jar of VERY FINE valve grinding compound. Mount about 14 to 18 inches of the dowel rod to a 1 x 3 board, . . . apply the grinding compound to the top of the dowel, and pull backwards on the handle of the bevler, . . . the opposite way of beveling leather. The first time you do this, . . . you will be matching the dowel diameter to the beveler, . . . and it may take 20 or thirty minutes, your arm get tired, and you may say phooey on it. Stay with it, . . . about every ten strokes, . . . try your beveler on a piece of scrap leather. Once you see it is starting to cut a lot better, . . . take about 15 or 20 more sharpening strokes. Then use your beveler to bevel the edges of a piece of 9, 10, 12 or so oz leather, . . . about 14 to 18 inches long. Get it wet and allow it to dry so it hardens up, . . . rub jeweler's rouge on that rounded leather edge, . . . and from now on, . . . THAT is the strop you use for your beveler. Quote www.facebook.com/alteredleather
Members thekid77 Posted April 15, 2013 Members Report Posted April 15, 2013 just get a piece of leather and bevel the edge...rub some green chrome polish on the beveled edge of the leather, then strop the beveler a few times by stroking the beveler over the beveled edge (make sure you pull the beveler toward you or you'll wind up dulling the blade even more... ***note: this is only for bevelers that look like a forked tongue AND if your beveler is too dull, you may have to purchase something like a small dowel like Renee suggested...then you coul fold some 1000-1500 grit wet/dry sandpaper over that, and strop.... just make sure you are stropping the beveler in the opposite direction of the way it cuts, or you will have a dull useless tool...follow the link below: hope this helps Quote
Members Matt S Posted April 15, 2013 Members Report Posted April 15, 2013 I use a length of quite thick linen thread to strop the inside edge of my Ivan bevellers, tensioned in a cheap mini hacksaw frame, strengthened with beeswax and rubbed periodically with jewellers rouge. Works great. Quote
electrathon Posted April 15, 2013 Report Posted April 15, 2013 Use a piece of wire that fits inside the bevaler (like a small welding rod, coat hanger, etc) and lay a piece of ultra fine sandpaper over the wire. Draw the beveler backwards down the wire. pull straight back, do not rotate your hand as you pull. Quote
Members CADBURYS Posted April 15, 2013 Author Members Report Posted April 15, 2013 thanks a lot for these tips much appriciated Quote rough & ready ,& busy chasing the grandkids
