Members Buckinger Posted May 10, 2013 Members Report Posted May 10, 2013 Hi, I am new to leather and dived straight in and bought a leather sewing machine. I'm loving it. However, I've made a few wallets and I am noticing a problem I don't know how to fix. If you look at the photo below, you'll see the bottom holes are not clean - the leather gets pushed out. On this wallet, I sewed the top holes from the top and the bottom holes from the reverse side, so you can see the difference. So the problem holes are what happens to the under side of the wallet when I am running it through the machine. This problem doesn't happen with all leathers. Just this buffalo calf. Any idea why this is happening and how I can fix it? Thanks, James Quote
Members EquusCustomLeathers Posted May 10, 2013 Members Report Posted May 10, 2013 At first glance, I would guess that maybe you have a dull needle..just a thought Quote
Northmount Posted May 10, 2013 Report Posted May 10, 2013 This is normal. The leather has to be displaced by the needle. Not the same as fabric. Smaller needle, smaller thread can reduce the amount. Leather needles may help. You can pound the rough side down with a smooth faced hammer. Don't go at it too hard! Moistening the leather slightly after sewing and slicking it with a bone folder or slicker will also help smooth it out. Will also help remove feeddog marks. Tom Quote
Members Buckinger Posted May 10, 2013 Author Members Report Posted May 10, 2013 Thank you for your suggestions. I will try putting in a new needle. The needle size in the machine is a 140/22. I am using 69 thread. What would be the next size down and would I also need to use a different size thread if I use a different needle? I tried smoothing it down with a bone folder as you suggested, Tom, and it did help, but it still doesn't look as nice as the other side. Best, James Quote
Northmount Posted May 11, 2013 Report Posted May 11, 2013 Bottom side will never look as good as the top side of the stitch. Needle and thread size chart at Toledo Industrial (and other places too) http://www.tolindsewmach.com/thread-chart.html Tom Quote
Moderator Wizcrafts Posted May 12, 2013 Moderator Report Posted May 12, 2013 If you are using a #22 needle with #69 thread, it is 4 sizes too big for the thread. A #22 needle is meant for use with #138 thread. #69 thread should be sewn using a #16 or #18 needle. Leather should always be sewn with a leather point needle. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Buckinger Posted May 13, 2013 Author Members Report Posted May 13, 2013 Thank you for the info. I did get some #16 needles and it is a definite improvement, but I just checked and they are universal needles, so I will get some leather point ones. Appreciate the help. James Quote
Tree Reaper Posted May 16, 2013 Report Posted May 16, 2013 Flip the wallet over and sew from the finished side towards the inside. Back up interior down. Quote
