Members supercub Posted August 22, 2013 Members Report Posted August 22, 2013 The "stand off" piece or spacer helps for a tuckable holster to provide a little more space between the holster body and strap so you can tuck a shirt over the gun and between the holster and belt for maximum concealment. It also helps a little on a non tuckable IWB - saving wear on the underside of your strap loops where they rub. Quote
Members Jumpout Posted August 26, 2013 Members Report Posted August 26, 2013 I also use t-nuts pushed through from the backside of the holster. Then secured with a screw through the belt strap. When I install the screw I use blue loctite. And I have also found you have to really pay attention when ordering the male parts of those Pull the Dot snaps! Quote
Members malabar Posted September 2, 2013 Members Report Posted September 2, 2013 I've only made a couple of hundred holsters like this, so I don't have the extensive experience that Ray does. But I bury the the t-nuts between the layers of leather. On my IWBs, I attach the straps the way that Milt Sparks does -- I have a separate tab and spacer stitched to the strap, and I secure them with a pair of t-nuts. Lobo's right -- you can certainly strip these things out, but my personal experience has been that the only ones I have problems with come out of the box bad. I've never had a client strip them, but then, because they are attached at two points, they never loosen, and the client doesn't have to touch them. Similarly, my most popular holster has replaceable straps that are held in place by a single t-nut, but because the strap threads through the body of the holster before being screwed down, these never loosen, either. Of course, it might be that after a few more years of business, I find out otherwise. Now, I have had clients destroy the one-way snaps from putting them on the wrong way <g> tk Quote
Members TKanaley Posted September 6, 2013 Members Report Posted September 6, 2013 Generally we go through roughly 15,000 - 20,000 Tnuts in the making of our holsters each and every year. We also as a matter of doing things the way that we do, bury our Tnuts between the layers of leather rather than having an exposed metal flange on the backside of the holster. The only exceptions are our tension welt holsters and a couple of our mag pouch designs where the baseplate of the Tnut doesn't show or come into contact with bare flesh. Though it is possible to spin a Tnut if you overtighten, or cross thread the screw going into it. It is an event that very rarely happens, at least with our product. Last year I replaced Tnuts on two different holsters that were at least 10 years old and failed due to operator error. Both repairs took me less than 15 minutes. Keep in mind that we ship between $800,000 and $900,000 worth of holsters/mag pouches/belts every year. That's a lot of product each year with little to no returns for repair. Spinning Tnuts have not been a problem for us and we've been using them for well over 40 years. One thing we don't do with Tnuts is clip the prongs shorter and there's a reason for that. We set all our Tnuts with a 1/4" thick, flat metal tongue that has a hole drilled near the end that's just a little larger diameter and a little thicker than the barrel of the Tnut. To drive the Tnuts into the leather, we position the base of the Tnut over a small anvil and wack the metal tongue with a lead weighted, rawhide mallet causing the tips of the prongs to clinch over as they are driven through the leather and into the bottom of the metal tongue. Occasionally we'll find the need to have to remove a Tnut during production, but I can tell you that once the nut has been set in the above manner, it takes more than just a little a bit of effort to remove. Driving and clinching the tips of the Tnut prongs has roughly the same effect as clinching a horseshoe nail into the wall of the hoof after you've drove the nail and clipped it. As any experienced farrier knows, a horse won't be wearing his shoes very long if the nails aren't clinched. And if you don't clinch a buried Tnut, you might end up spending more time repairing spinning Tnuts than you want. Lastly, anyone concerned about the aesthetics of the clinched-over points being exposed, they are covered up with the snap or strap for which you put the Tnut there to begin with. No problem... T Quote http://www.miltsparks.com. Second best is not an option
Members Red Cent Posted September 7, 2013 Members Report Posted September 7, 2013 For those of us who are mumbling "What the heck are ........". We have seen them but terms escape us (me). Quote https://www.facebook.com/redcentcustomleather?ref=bookmarks http://www.redcentcustomleather.com/
Members malabar Posted September 9, 2013 Members Report Posted September 9, 2013 Tony, Thanks for weighing in. You said that you repaired two holsters with stripped t-nuts last year: Would you mind sharing your procedure for replacing the t-nut? many thanks tk Quote
Members TKanaley Posted September 9, 2013 Members Report Posted September 9, 2013 Tony, Thanks for weighing in. You said that you repaired two holsters with stripped t-nuts last year: Would you mind sharing your procedure for replacing the t-nut? many thanks tk Sure, you cut the thread by inserting a knife between the layers of leather, pull out a few stitches and remove the damaged Tnut with a pair of needle nose pliers. Replace Tnut, clinch, glue and handstitch through the old stitch holes (or machine stitch if at all possible), re-burnish the edge and you're done. Like I said, it's a simple procedure and it usually takes me less than 15 minutes. I've replaced quite a few corroded brass snap studs with Tnuts on old 20 to 35 year old Summer Specials. Same procedure as above, but additionally I have to grind the barrel of the Tnut down once the Tnuts are set in the leather, so that the male snaps sit flush to the topband once they are screwed in place. Makes them good for another 20 to 35 years. T Quote http://www.miltsparks.com. Second best is not an option
Members malabar Posted September 9, 2013 Members Report Posted September 9, 2013 Slick. Must be gratiying to see your gear still in use after all that time. many thanks for the pointers. tk Quote
