Members Murf Posted June 20, 2013 Members Report Posted June 20, 2013 There is probably already a thread on this but i had no luck searching it. Currently i am transferring my images onto the leather with a modeling stylus the image on top, then Grey/white transfer paper (Depending on the dye or antique) onto cased leather rubbed with a glass burnisher. as you can guess i have had issues with the white not showing up well (in some cases its clear as day) and issues with the gray getting embedded into the leather then i have to dye or antique to cover it up. I was hoping to get a collective on how the rest of you transfer your carving image. I know really experienced toolers freehand with their swivel knife but personally im just not that confident in my skills at this point. Thanks, Murf Quote I tried to draw comics for a few years... I was a medic for a few years... Using a wrench is in my blood forever. Somewhere in that mess I picked up a piece of leather and made a dog collar, I was finally satisfied with something I had done. Everyday I marvel at the things I have made, and I am happy...
Members Dwight Posted June 20, 2013 Members Report Posted June 20, 2013 I use only clear or "almost clear" plastic for my images. I place that image on the wetted leather, . . . it may not have dried to the point it would be called "cased", . . . but you most surely can call it wet. I use the pointed end of a stylus tool that rubbs the plastic but doesn't cut it, . . . transferring a drawn image to the wetted leather. I use those impressions in the wetted leather as my pattern, . . . and the image can be used over, over, and over again. I got a really good deal some years back on some 8 1/2 x 11 transparency sheets used for computer printing. I'm still working on that box, . . . but almost any thin, clear plastic will work. AND, . . . if the leather is WET instead of just CASED, . . . the plastic will lay down and not move on the leather while you are tracing your image onto the leather. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Members lightingale Posted June 20, 2013 Members Report Posted June 20, 2013 I scan my sketches into the computer and print out a template. I cut the template to fit to the edge of the leather, and hold or tape it down. I draw over it with a stylus. The leather is cased so the lines take on a little burnish and are easy to see. I can flip up the paper to see if I missed any lines. Once my template gets a bit ratty from use, I print out a new one. Quote Salukifeathers.com
Members Cyberthrasher Posted June 20, 2013 Members Report Posted June 20, 2013 tracing paper backed with packing tape. You'll actually find that MOST don't freehand. At the very least, there's usually a transferred guideline of some kind. There actually is another thread with LOTS of options: "Alternatives to Tandy tracing film" http://leatherworker.net/forum/index.php?showtopic=34118 I think what you may be having issues with is that it sounds like you're trying to do a "carbon copy" type transfer. If the leather is wet, then when you go over your design with a stylus, you'll have an imprinted line to follow - no worrying about the color. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members SeekingPerfection Posted June 21, 2013 Members Report Posted June 21, 2013 are you trying to transfer the colors onto the leather? That typically comes later in the process (after tooling). You don't really want any color's bleeding onto your leather; which is part of the reason for the packing tape. All you want to do is trace the image at this point. If I read your OP wrong simply disregard. Quote
Members coop Posted June 25, 2013 Members Report Posted June 25, 2013 I have been using Saral (grey) non-wax on dry leather to transfer my designs with the stylus. You can use the same sheet three or four times and once it is cut I go over it with a large red eraser and it removes any traces that are left. Quote
Members Cyberthrasher Posted June 26, 2013 Members Report Posted June 26, 2013 On 6/25/2013 at 11:14 PM, coop said: once it is cut I go over it with a large red eraser and it removes any traces that are left. Isn't that an unnecessary step when considering all the other transfer methods available (and risky if you happen to not get it all off)? On a similar note, I see a lot of people who try to just get the artwork directly on the leather without tracing it out first. Some people even do it in such a way that they NEVER acquaint themselves with the design before cutting it. I want people to think of the tracing (to get it onto the transfer sheet) as ONE MORE step in getting familiar with the design and HOW it should be cut/tooled. Each and every time you go over a piece of artwork, you should be thinking ahead of time about how you will cut and tool it. So, by drawing, tracing, then transferring - you've now acquainted yourself with all the lines 3 times. If you didn't draw it from scratch, you can see where this is even more vital to the successful outcome of the work because you'll only have 2 times to get familiar with it. Now, if you use a carbon copy method (such as Saral paper), then you're only going over the design ONE time before tooling it. Think of all the times you've gotten mad about a piece and redid it to realize that you were better acquainted with the design now and could pull it off better. This is the same exact concept, except you're not wasting any material by ensuring that you're familiar with your work before you ever take knife to leather. Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members Murf Posted June 26, 2013 Author Members Report Posted June 26, 2013 On 6/26/2013 at 4:00 AM, Cyberthrasher said: Isn't that an unnecessary step when considering all the other transfer methods available (and risky if you happen to not get it all off)? On a similar note, I see a lot of people who try to just get the artwork directly on the leather without tracing it out first. Some people even do it in such a way that they NEVER acquaint themselves with the design before cutting it. I want people to think of the tracing (to get it onto the transfer sheet) as ONE MORE step in getting familiar with the design and HOW it should be cut/tooled. Each and every time you go over a piece of artwork, you should be thinking ahead of time about how you will cut and tool it. So, by drawing, tracing, then transferring - you've now acquainted yourself with all the lines 3 times. If you didn't draw it from scratch, you can see where this is even more vital to the successful outcome of the work because you'll only have 2 times to get familiar with it. Now, if you use a carbon copy method (such as Saral paper), then you're only going over the design ONE time before tooling it. Think of all the times you've gotten mad about a piece and redid it to realize that you were better acquainted with the design now and could pull it off better. This is the same exact concept, except you're not wasting any material by ensuring that you're familiar with your work before you ever take knife to leather. Im not familiar with the method mentioned, even though im looking for a new method i look at it like this, Drawing = 1st draft, I then light box my drawing and go over it with a sharpie fine point = revision 1, Then the transfer = revision 2, and then the knife = revision 3. this gives me alot of experience with the image and it give me a chance to space things and think about the carving and tooling each time i go over it. "will that bevel crash with another", or "ill gap this out more so the back grounding has more area". Question @ cyberthrasher- You mentioned backing your images with packing tape then using a stylus. How wet is you leather when you do this? im reinventing how i transfer and im struggling with the image not enduring the carving session. Quote I tried to draw comics for a few years... I was a medic for a few years... Using a wrench is in my blood forever. Somewhere in that mess I picked up a piece of leather and made a dog collar, I was finally satisfied with something I had done. Everyday I marvel at the things I have made, and I am happy...
Members Cyberthrasher Posted June 26, 2013 Members Report Posted June 26, 2013 (edited) On 6/26/2013 at 5:38 AM, Murf said: Question @ cyberthrasher- You mentioned backing your images with packing tape then using a stylus. How wet is you leather when you do this? im reinventing how i transfer and im struggling with the image not enduring the carving session. Simple answer - cased. But, even a little bit of dampness from moistening with a sponge will give you a good enough impression to last throughout your tooling. This is the way we've all been taught to transfer our images and it works. The ONLY reason I back my design with packing tape is because I'm too cheap to buy Tandy's expensive and unnecessary transfer film. I spend $2 on a big pad of tracing paper and just put a piece of packing tape on the back. The packing tape keeps me from poking through, makes it last a lot longer (if I need to use it more than once), and keeps the moisture from distorting it. By doing it this way, the image is transferred by making a LIGHT impression in the leather, which translates to nothing to rub off. Oh yeah, and the "Saral paper" is basically what it sounds like you're using - colored transfer paper that works just like carbon paper. Edited June 26, 2013 by Cyberthrasher Quote hellhoundkustoms.wordpress.com www.facebook.com/hellhoundkustoms www.etsy.com/shop/HellhoundKustoms
Members coop Posted June 26, 2013 Members Report Posted June 26, 2013 I haven't had any ill effects from the Saral as of yet (nothing embedded in the leather). I was reccomended it by a buddy that makes saddles and before I was referred to this site by Cyber and learned about the duct tape method. I draw everything I do and then trace it onto tracing paper to clean it up. I just figured it was a given that the person would be familar and able to draw the design, at least practice it on scrap first?? If I have issues with the Saral I will convert to the duct tape myself. Quote
