22 hours ago, Wizcrafts said:
It's a piece of cake if you are a pedal steel player, like me!
The musician gene jumped over me and went straight to my Grandson.  He is a blessed and talented lead guitar player with his own band. I could never get both of my hands to work together on a guitar, regrettably with the nerve damage in my legs and feet from 3 back surgeries my feet are not super cooperative to instructions for what pedal to push. Everything that I do has to be slow and deliberate.  Not whining about what I have , just explaining. I am determined to make it work.  At 71 years old I'm too thick headed to say I can't do this and just give up. I will get it done slower is all :cheers:
Thanks for everyone's advise and tips it's saving me a lot of rework.
 Best Regards, Terry
  • Replies 181
  • Created
  • Last Reply
Top Posters In This Topic
 Best Regards, Terry
I'm lucky to be a pretty fair musician, but I've never been able to get my hands to move the right way to play stringed instruments ... Other than the ol' 88 string.  :)
- Bill
Here is another update on my home  made table for my cobra 26. I did a test fit for the machine and pulleys to see how it all works.
The first picture is the way the machine will mount through the angle, the 2x4 is slightly thicker than the table will be.
It works great, I'm happy.
The 12"and 2" pulley setup  really increases the torque and keeps the speed where it is completely controllable even on the 3rd setting on the servo
The go pedal has a built stop to keeping from  going over center and sticking the motor on. I still have to work out the presser lift pedal and linkage.
There is a better view of the go pedal and stop linkage
There is a better view of the go pedal and stop linkage . And how I mounted  the servo.
  • 2 months later...
On 7/24/2013 at 11:54 AM, thesergeant said:
HI Can you tell me... did you use a template and router for the corners?
On this subject: Does anyone have a dimensioned drawing of the table cutout for a Juki LG-158 (30") ? I need to make a new custom replacement as the one which came with my machine is so degraded and warped that I don't want to use it for measuring. I THINK but don't know with certainty that the Singer 144W30x table measures the same but I don't have one locally to double check the exact hinge mortise locations. Any pointers to a site that might have such things would be appreciated!  TIA  -DC
Machines: Juki LU-563, Consew 206-RB5, Singer 20U33, Pfaff 481, Mitsubishi CU-865-22, Consew 29B, Rebadged Juki LU-562,  Mitsubishi LS2-180,  Seiko SK-6, Juki LG-158-1
  • 1 year later...
On 11/16/2015 at 6:34 PM, Uwe said:
Here's a DXF export I did earlier today. It'll take some tweaking but it's a good starting point. Let's hope this works:
http://uwe.net/CAD/Consew225_v2.dxf
Uwe any chance you still have the dxf or v-carve files lying around still? Looks like those links are no longer working.
I just bought an old Consew 254 with a deteriorating table and was hoping to build a new one. I have access to a ShopBot at a facility that uses V-Carve so either file type would be greatly appreciated!
