Members TXAG Posted November 10, 2013 Author Members Report Posted November 10, 2013 (edited) I appreciate your posting the details on this for me very much...unfortunately, I cannot understand the grid diagrams...at least not yet. I haven't been able to find an explanation of how they work that makes sense to me. I will try to study it until it makes sense though...I'll try putting it on a TP tube and see if I can get it then. Wish I could just find a simple O/U formula for adding a different color... Edited November 10, 2013 by TXAG Quote
Members fancye9876 Posted November 10, 2013 Members Report Posted November 10, 2013 I can't follow those graphs yet either. Seems nothing is simple. I have the Marlinspike Knot Works DVD and it is the simpliest I have found. He does an interweave with a second color. I also have Gail's book The Art Of Braiding Revised. I found her instructions hard to follow but finally managed to get the pinapple knot figured out and then the interweave was not to bad. I still have to look at the instructions even after making a dozen or so. One mistake messes the whole thing up. Have had to start over 4 times on one knot but got it done. I also would like to figure out how to do interweaves using more than one color for the interweave. Quote
Members skyout Posted November 10, 2013 Members Report Posted November 10, 2013 (edited) I learned a lot from the late Dan Alaska's tuts. http://pineappleknot...icles-blog.html Edited November 10, 2013 by skyout Quote
Members KnotHead Posted November 12, 2013 Members Report Posted November 12, 2013 Following a grid is just like keeping the colors you use in a coloring book inside the lines, or building a train track and putting the train on the track, or placing a hot wheel on a rubber/plastic track and pushing it down the track, or even better; doing a dot to dot drawing like in the old dot to dot booklets. Just wrap the grid around a postal tube, or toilet paper tube and then follow the lines from one point to the other. Brian... Quote Best Regards, Brian Kidd
Members GrampaJoel Posted November 12, 2013 Members Report Posted November 12, 2013 What knot head said. Put the grid around a tube it fits, and the grid map usually becomes pretty clear. Quote
Members TXAG Posted November 12, 2013 Author Members Report Posted November 12, 2013 Following a grid is just like keeping the colors you use in a coloring book inside the lines, or building a train track and putting the train on the track, or placing a hot wheel on a rubber/plastic track and pushing it down the track, or even better; doing a dot to dot drawing like in the old dot to dot booklets. Just wrap the grid around a postal tube, or toilet paper tube and then follow the lines from one point to the other. Brian... Well. I was able to tie a couple of patterns without having to resort to that grid thing. Received instructions using simple over/under explanations and it worked fine. I'll post pics of proof later. Quote
Members TXAG Posted November 12, 2013 Author Members Report Posted November 12, 2013 (edited) Again, I am stuck having to make a new post instead of editing my old one due to the restrictively short edit buffer. Here is one of the knots I made without the grid thing...(and the lace is some junky quality 3/32" roo lace I got from Springfield Leather. It is very dry and doesn't lay right (to me)...guess I was spoiled by the quality of the first roo lace (drum stuffed) I bought from a guy in Australia...) Edited November 12, 2013 by TXAG Quote
Members fancye9876 Posted November 12, 2013 Members Report Posted November 12, 2013 I like the pattern Quote
Members TXAG Posted November 12, 2013 Author Members Report Posted November 12, 2013 Thanks...I am partial to the chevron pattern also. I made a "barber pole" pattern last night too, but it is at home. I'll probably add a pic of it later today... Quote
Members TXAG Posted November 13, 2013 Author Members Report Posted November 13, 2013 Made this with roo lace I cut... Quote
