Members Miss KamiKaze Posted October 23, 2013 Members Report Posted October 23, 2013 (edited) Hi there, I got this machine from someone who used to make leather purses. It came with no manual. I make some 'heavy' Nylon dog collars... Been using the machine for about 2months now, not one issues... Well recently when I go to tack the ends.. (which ive done 1000 times) * Yes its a new needle btw* the needle seems like it hits something and bends/breaks. Its never done this in the past... and I haven't changed my materials or anything. Use a size 20 needle. I ordered a new bobbin casing just for tries. Thanks so much for anyone who took the time to read/reply =) Edited October 23, 2013 by Miss KamiKaze Quote
Members Miss KamiKaze Posted October 23, 2013 Author Members Report Posted October 23, 2013 (edited) Heres a vid. don't mind the noise, thats only my phone being weird..not the machine. Brand new needle btw. re threaded, newly winded bobbin, oiled.... and it only seems to happen when Im goin through 4. Which it has does more completely fine for the past 2 months. Edited October 23, 2013 by Miss KamiKaze Quote
Members Miss KamiKaze Posted October 23, 2013 Author Members Report Posted October 23, 2013 I really need to get this figured out, I have 4 custom collars I need to make!!! SOme one please chime in and shoot me some ideas!!! please Quote
Members cdthayer Posted October 23, 2013 Members Report Posted October 23, 2013 Since I'm not out there in the bikeshop sewing my son's coveralls up with my Singer 31-15, I might as well try to help you with your problem. First thing that I would do, is remove the bobbin case, take the bobbin and thread out of the case, and put it all back together again making sure it's threaded correctly, and then put the bobbin case back onto the machine, making sure it's installed correctly. Sounds to me like your BC is not latched in properly. Second, put in a new needle, even if you've just done that. Take the upper thread completely out of the thread guides, and then rethread the upper part of the machine again. Test sew by hand turning the wheel, and keep going for a while even if it seems to sew without the needle hitting anything. CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Moderator Wizcrafts Posted October 23, 2013 Moderator Report Posted October 23, 2013 (edited) I have another suggestion, which I myself have followed. Your needles are bending and breaking due to deflection from multiple layers, which causes the needle to miss the hole and hit the solid steel plate. Changing the original throat plate and feed dog to a heavy duty set may cure the problem! These are usually sold as a two piece matched set of an oversize feed dog and matching throat plate. The important thing you'll be interested in is that the needle hole is larger in this heavy set than in the standard or medium duty sets. You can use a #22 needle with the heavy set, which means more wiggle room for your #20 before the deflected needle hits the throat plate. As suggested by the previous poster, check the lateral clearance betwixt your needle and the hook. Edited October 23, 2013 by Wizcrafts Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Miss KamiKaze Posted October 24, 2013 Author Members Report Posted October 24, 2013 Thank You Guys so much for your time/advice! Im going to search on eBay for the heavier feed dog / throat plate! I didn't know about that!! I will be trying again and making sure the bobbin casing is snapped in tightly. I did notice that the casing never really makes the 'snap' locating sound as my other machine did. Hopefully the new casing will!! Again thank you two very much for your help!! Knowlwdge is power and Im just a noob. haha. ) <3 many thanks! -K Quote
Members cdthayer Posted October 24, 2013 Members Report Posted October 24, 2013 You can get too much bulk under the needle for the needle to penetrate on a Singer 31-15, even though the foot raises high enough for it to fit under the presser bar. I did it a couple of times yesterday while sewing on insulated duck overalls that I'm removing the full-length zippers in the sides and sewing the legs shut from the knee up. I was using Tex90 UV-resistant thread in a size 18 needle. On the bottom hem of the leg where all of the various layers with all of their turn-unders come together at the corner, I got a "thunk" a couple of times when it was simply too thick to penetrate. I always hand-crank the machine when I'm sewing those areas, mainly because it's hard for the roller wheel to crawl up on those lumps, and I'm sewing with a treadle. Sometimes I can rock the wheel back and forth a few times to get the needle through, but other times it just won't go. It sounds and feels like the needle is hitting something solid, but it's not going through even to the needle plate. There is enough material to stop the needle. If you've been going back to tack the preceding stitch line, you may be getting the same problem. Are you using a different brand of webbing than you had been using before? Maybe with a tighter weave? Have you sized your needle or thread up from before? The larger the needle, the more this will happen. Use the smallest needle that you can for the thread size that you're using. When you get onto thick woven stuff, using a large needle and thick thread, you may run into this from time to time in my experience. CD in Oklahoma Quote "I sew, I sew, so it's off to work I go....." My sewing machines:Adler 205-370 (Hand Crank), Adler 205-64 (Hand Crank), Consew 226 (Clutch/Speed Reducer), Singer 111G156 (Hand Crank or Clutch), Singer 111W153 (Clutch), Singer 20U33 (Clutch), Singer 78-3 Needlefeed (Treadle), Singer 20U (Treadle), Singer 29K70 (x2) (Both Treadle/Hand Crank), Singer 96-40 w/Darning Foot (Treadle), Singer 31-15 w/Roller Foot (Treadle), Singer 31-15 (Hand Crank), Singer 16-41 (Treadle), Singer 66-1 (Treadle/Hand Crank), Singer 201K4 (Treadle/Hand Crank), Singer 216G Zigzag (Treadle/Hand Crank), Singer 319W (Treadle)
Members Miss KamiKaze Posted October 30, 2013 Author Members Report Posted October 30, 2013 You can get too much bulk under the needle for the needle to penetrate on a Singer 31-15, even though the foot raises high enough for it to fit under the presser bar. I did it a couple of times yesterday while sewing on insulated duck overalls that I'm removing the full-length zippers in the sides and sewing the legs shut from the knee up. I was using Tex90 UV-resistant thread in a size 18 needle. On the bottom hem of the leg where all of the various layers with all of their turn-unders come together at the corner, I got a "thunk" a couple of times when it was simply too thick to penetrate. I always hand-crank the machine when I'm sewing those areas, mainly because it's hard for the roller wheel to crawl up on those lumps, and I'm sewing with a treadle. Sometimes I can rock the wheel back and forth a few times to get the needle through, but other times it just won't go. It sounds and feels like the needle is hitting something solid, but it's not going through even to the needle plate. There is enough material to stop the needle. If you've been going back to tack the preceding stitch line, you may be getting the same problem. Are you using a different brand of webbing than you had been using before? Maybe with a tighter weave? Have you sized your needle or thread up from before? The larger the needle, the more this will happen. Use the smallest needle that you can for the thread size that you're using. When you get onto thick woven stuff, using a large needle and thick thread, you may run into this from time to time in my experience. CD in Oklahoma Word this work?? http://www.ebay.com/itm/Singer-31-15-Heavy-duty-Needle-Plate-Feed-Dog-143169-149165-/280907843365?pt=LH_DefaultDomain_0&hash=item4167698725 Quote
Moderator Wizcrafts Posted October 30, 2013 Moderator Report Posted October 30, 2013 Yep, that's the set I bought. The teeth are very wide and aggressive. The needle hole is as large enough to pass a #25 needle. It is definitely a very heavy duty feeder set. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Slow Learner Posted October 30, 2013 Members Report Posted October 30, 2013 I know this is off topic but since there are 31-15 users I thought someone here could help. My Singer 31-15 keeps breaking the thread when I sew leather but does ok when I sew heaver cloth. I have had the bobbin case, feed dogs and still the problem continues. I am wanting to put a servo motor and reducer wheel to slow the machine down and maybe that will fix the problem. Any idea? and Which motor and wheel should I use? Oh I forgot. I am using #16 leather needle and #46 Bonded nylon thread. Quote
