Where To Get A Custom Made Transfer? - Like Craftaid Does For Carvings
G'day
Just wondering if anyone knows of somewhere I could get these made up from?
I would like to make my own designs and then be able to use them over and over - having something I could see through would be wonderful.
Cheers
Josh
Most of us just use transfer paper, but many use overhead projector sheets that will last a long time through several uses. Myself, I reuse the piece of tracing paper quite a bit by just putting a piece of clear packing tape on the back of it for protection.
Thanks Cyberthrasher, I also use transfer paper.
I am after exactly what I have described above, a clear plastic sheet with raised impressions to speed up the process and make it neater.
Cheers
Josh
If you're set on it, I would contact a company like Black River Laser and see if they can work with you on it. I'm just not sure if they can do something like the raised impressions.
That said, keep in mind that the best way to speed up the process is to practice. I point this out because quality work depends on KNOWING your design. We KNOW our design by tracing it onto transfer paper, and then going over it again with a stylus. With that method, you'll KNOW exactly what needs to happen at each portion of the design when you're tooling it, which translates to less time stopping to think about the design and better work overall. You can prove this to yourself by doing the same design a few times and taking note of how it improves overall with each attempt.
Thanks I know of Black River Laser and I was thinking on contacting them :)
Thank you for the advise, I am however not a novice and get plenty of practice.
Everyone has their own process, and as such a template would aid mine greatly.
Cheers
Josh
Another option would be to make your own "tap off". I just recently heard about them and gave it a try on some mirror image carved straps and it worked very well. Basically just carve the a mirrored outline of the pattern you want a template of in a heavy piece of scrap, dry it with some heat to harden the leather then put a cot of sealer on it. To use it just set it carved side down on your cased leather and tap the backside with a smooth faced hammer.
Good luck, Josh
Treed, you are wonderful- exactly what I was after! Thank you so much :thumbsup:
G'day Josh Ashman
I know of the 'tap off' method, it works - just not as well as a clear see through plastic sheet ;) Thank you for the advice :)
Cheers
Josh
I create my art work with Corel Draw then print on an overhead projector clear plastic sheet. They can be used many times. When tracing on the leather be sure the printed side is up otherwise it will transfer to the leather.
  • 3 years later...
On 10/29/2013 at 5:08 PM, Josh33806 said:
G'day
Cheers
Josh
Have you found one? Looking as well.
