thanks for the help. i di hem 3 pairs of jeans and turned out good.
this trick i found on you tube about cutting out a little bit of that heavy hump
made it easy going over.
Nice job. You'll likely get some fray there where it's notched, but the rest of the rolled hem will keep it in check.
Regards, Eric
Actually, I do have a compound walking-foot machine, but I'm a novice and sometimes I get over the seams easily and sometimes find the jean-a-ma-jig helpful.
thanks, I love all the 'tricks" keep n comin
For a little more detail, I use seam-stick rather than pins. Since seam-stick tends to gum-up the needle, it is applied toward the center of the hem away from the stitch line. The inside, flat-feeled seam is the hardest to get over, so I start toward the back on top of that seam, sew a few stitches, back-tack and then sew off that hump rather than over it. Starting on that seam also means that the starting and ending back-tacks are less visible. The regular seam on the other side is relatively easy to get over. The jean-a-ma-jig is helpful finishing on the flat-felled seam.
Very close to what I do.
I use a walking foot machine using a #21 needle and #69 bonded nylon thread ( because thats what I build all my gear with).
I use sail tape ( a 3/8" double sided tape that doesn't stick to the needle) to hold my first roll then I chalk a line on the outside that I use as a guide for my second roll.
I start sewing on the inside of the leg behind the thick seam, to better hide my start and stop. I use a guide made out of a strip of 1/4" foam attached to my machine using the same double sided tape.
This method works like a champ and I have never had a seam failure.
Scott
We cheat in the factory when hemming our jeans. It's a Union Special 63900T which is a cylinder machine set up with a compensating foot. It has small rollers on the bottom and just to make sure the seams can be sewed over at high speed, there's a close-coupled puller. To cheat further, it also has an air operated hemming folder that makes a perfect 5/8" rolled hem. We bought 3 of these when we first made Levi's in the 80's. They are pretty bulletproof, made in Chicago. Each leg takes about 12 seconds depending on the operator. I do soak the Tex 80 thread in silicone to prevent melting. I'll snap a pic if I remember, it's a cool old machine.
Regards, Eric
Eric works in a magic place; a sewing Wonderland that most mortals can never see.
Posted IMHO, by Wiz
