Members Wishful Posted December 9, 2013 Members Report Posted December 9, 2013 (edited) Not sure what I did exactly but while cleaning and oiling my machine, the rear presser foot is not lowering even though the lever is down. It is also not moving when I run the machine. I did not intentionally change anything but must have. Would it be the presser bar spring or knee lift lever? Any ideas? I appreciate any leads. Edited December 9, 2013 by Wishful Quote
Members Constabulary Posted December 9, 2013 Members Report Posted December 9, 2013 This would be my 1st idea. Check the parts 1.), 2.) and 3.) in the picture if their screws are loose and check if part 1.) is moving when you lift the foot lever and check is parts 2.) + 3.) are moving when you turn the hand wheel. Screws for the parts are all accessible from the backside. I assume screw of part 1.) is loose. But it can´t be wrong to check them all. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
CowboyBob Posted December 9, 2013 Report Posted December 9, 2013 2nd idea,There's a vertical rod for the knee lifter on the back that if you tilted the machine back & set it back down could of gotten in a bind. Quote Bob Kovar Toledo Industrial Sewing Machine Sales Ltd. 3631 Marine Rd Toledo,Ohio 43609 1-866-362-7397
Members Wishful Posted December 10, 2013 Author Members Report Posted December 10, 2013 (edited) Thanks for the input guys, and the pix. The knee lifter seems fine, as does items 1 is loose. 2 and 3 are not moving , maybe that is it. I cannot turn screw 2 yet. Should they be loose or tight? Edited December 10, 2013 by Wishful Quote
Moderator Wizcrafts Posted December 10, 2013 Moderator Report Posted December 10, 2013 You may need to apply penetrating oil to loosen the grip of the screws. They are normally tight, but not so much that they can't be unscrewed when necessary. Quote Posted IMHO, by Wiz My current crop of sewing machines: Cowboy CB4500, Singer 107w3, Singer 139w109, Singer 168G101, Singer 29k71, Singer 31-15, Singer 111w103, Singer 211G156, Adler 30-7 on power stand, Fortuna power skiver and a Pfaff 4 thread 2 needle serger.
Members Constabulary Posted December 10, 2013 Members Report Posted December 10, 2013 (edited) So with other words the presser foot is stuck in its position, right? Then before you loose the screws on part 1.) + 2.) check the part that looks like a fork and part 3.) is sitting in. The part is secured with a small screw from the backside. Loose the screw a 1/2 turn and try to adjust the "fork part" with a screw driver from the top side. The part has a slit. I had this problem with my Duerkopp 252 and a small adjustment on the fork part did the job. A thoroughly oiling could be useful as well. Edited December 10, 2013 by Constabulary Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Wishful Posted December 11, 2013 Author Members Report Posted December 11, 2013 (edited) Working on loosening the screw with liquid wrench. You are correct that the presser foot is stuck in the position. Does the presser foot eccentric play a role in the movement? If so how? Edited December 11, 2013 by Wishful Quote
Members Constabulary Posted December 11, 2013 Members Report Posted December 11, 2013 I looked closer at your picture and compared it with my machine with foot in lift up position. At your machine the part I numbered with 3.) seems to be quite far up in the fork when the foot is lift. At my machine it is in a much lower position even when foot is lifted. See pictures below Try to put flat screwdriver between the parts, use it as a lever and try to push down part 3.) I assume the fork part is too tight and the part 3.) is stuck there. Quote ~ Keep "OLD CAST IRON" alive - it´s worth it ~ Machines in use: - Singer 111G156 - Singer 307G2 - Singer 29K71 - Singer 212G141 - Singer 45D91 - Singer 132K6 - Singer 108W20 - Singer 51WSV2 - Singer 143W2
Members Wishful Posted December 12, 2013 Author Members Report Posted December 12, 2013 (edited) You are correct, I was able to loosen the upper screw and lower the shaft a bit but it is very tight which I assume is due to the lower screw. I planned on taking it to someone but they are tied up until after Christmas so I figured I would fuss with it until then. I downloaded the navy manual and will try to disassemble and reassemble to figure out whats up. it seems to me something has seized but I'm stumped. I appreciate you pix and ideas. Im trying to identify what actually moves that presser foot up and down during sewing Edited December 12, 2013 by Wishful Quote
Members Cbm Posted October 19, 2017 Members Report Posted October 19, 2017 i am having this same problem with my 111w155 i can lift the presser bar up with the lever but it doesnt actuate from the cams movement from the back of machine and all connections are tight. I am new to this forum and have seen this touched on in different ways but cant find the reason for this problem in past posts.I also know this is an older post Quote
