Members shinelightshine Posted January 5, 2014 Members Report Posted January 5, 2014 (edited) Hey guys! It's been a while since I've posted, so I thought I'd show you all what I've been working on. Recently I've finished a passport wallet, a couple glasses sleeves, a wallet, a key lanyard, a coin pouch, and a small tobacco pouch. Attached are some pics of the completed projects. Thanks for checking it out! -Nick Edited January 5, 2014 by shinelightshine Quote
Members benlilly1 Posted January 5, 2014 Members Report Posted January 5, 2014 VERY nice work, Nick! Quote
Members veedub3 Posted January 6, 2014 Members Report Posted January 6, 2014 They are all very nicely done! Quote
Members WScott Posted January 6, 2014 Members Report Posted January 6, 2014 Solid work Great looking stitching , nice design and professional appearance. "He's a good Canadian kid" Quote
Members r lenna Posted January 6, 2014 Members Report Posted January 6, 2014 That's Beautiful work. Nice stiching and lines Quote
Members Blak Smyth Posted January 6, 2014 Members Report Posted January 6, 2014 (edited) Everything looks really nice with good stitching. I really like the passport wallet. One thing I noticed is the snap on the tobacco pouch is smashed crooked. The use of a shorter snap will prevent this. I had the same problem at first because I was using a longer snap, switched to a line 20 short and it worked perfectly. Here is a link to the ones that worked for me. Edited January 6, 2014 by Blak Smyth Quote
Members shinelightshine Posted January 7, 2014 Author Members Report Posted January 7, 2014 Thanks a lot everyone . Everything looks really nice with good stitching. I really like the passport wallet. One thing I noticed is the snap on the tobacco pouch is smashed crooked. The use of a shorter snap will prevent this. I had the same problem at first because I was using a longer snap, switched to a line 20 short and it worked perfectly. Here is a link to the ones that worked for me. Thanks Blak Smyth! I appreciate the tip with the snap. I'll definitely try out the shorter ones. I think I may have over pounded the snap as well on the tobacco pouch as well. Quote
Members VonTannin Posted January 8, 2014 Members Report Posted January 8, 2014 Very very clean work. Another tip when it comes to snaps, if you have a dremel or something similar in your shop, just grind down the post of the snap until its the appropriate length, then set it. Usually takes about 5 seconds on a dremel with a drum sanding head. If you cut or snip the post, it won't flare right when you set it, but grinding it doesn't effect the flare at all. Quote
Members Mikexd40 Posted January 8, 2014 Members Report Posted January 8, 2014 What ounce if leather are you using? I really like your work. Very clean. Hand stitched or machine? Quote
Members AndiH Posted January 8, 2014 Members Report Posted January 8, 2014 I won't comment on the quality of work since those with greater experience have. I do have a style concern with the tobacco pouch though. With only a snap closure doesn't some of the tobacco escape? Quote
Members shinelightshine Posted January 8, 2014 Author Members Report Posted January 8, 2014 Very very clean work. Another tip when it comes to snaps, if you have a dremel or something similar in your shop, just grind down the post of the snap until its the appropriate length, then set it. Usually takes about 5 seconds on a dremel with a drum sanding head. If you cut or snip the post, it won't flare right when you set it, but grinding it doesn't effect the flare at all. Thanks VonTannin! That's a great idea, I'll definitely give that a shot. What ounce if leather are you using? I really like your work. Very clean. Hand stitched or machine? Thanks a lot! it's about 4oz I think, a little thicker in some pieces. The side that all these are made from was 4-5oz. I won't comment on the quality of work since those with greater experience have. I do have a style concern with the tobacco pouch though. With only a snap closure doesn't some of the tobacco escape? Yes, you're absolutely right. The tobacco does indeed flake out a little bit. I made another tobacco pouch for a friend that used a tuck closure instead and that worked much better (didn't leak at all). Another idea I had was to extend the front panel of the pouch up a bit, so that you could tuck it in and sort of cover the tobacco before snapping it shut. Quote
