Can I dye over them with an oil dye? I tried using a brown one on a piece and it is splotchy and uneven after many coats, you can see drips from the brush and darker streaks. I have done a bit of dying with the Fiebings oil dyes, and never had this trouble.
Hello. Yes, they do suck. The short answer is yes, you can go over them with a real dye.
Hello, no they don't suck, they have their place in the range of dyes available and can be great depending on what you are trying to achieve.
I've had pretty good luck with them. I apply it with a damp sponge and get good coverage. Honestly though if my dye jobs come out a little blotchy, I don't really mind as that suits my style of leatherwork. I antique all my items to give them a very rustic look.
Fiebing's Pro Oil Dye for my black though all the way. Tandy can't touch that stuff.
Have you tried the black from their pro line? I've been very impressed with it - world's away better than any of their other blacks.
I use the antique gels and like the finish I get from them, but the straight colours I have never had much success with the first time I used the black the item looked like that it had been painted but ... the finish has lasted with some quite abusive use. I use a lot of oil dyes and analine dyes which I find more consistent.
JM2CW....but I use their water dyes quite a bit, love the black, but anyway you said in the original post you were getting drips off the brush.......Doh!!!! If you read the tutorial it recommends application with a damp sponge,applied in a circular motion, and worked into the piece until the dye is just about dry. And Hey! It works really nicely I've found. I could see where it could be a problem on a small area, as I am usually dying an entire piece, but I have used it with a small brush as background and still had good results. Don't give up,try another method, you might be surprised. As I said earlier, the black is one of the easiest to use with great coverage that I have found........but I am certainly open to being proven wrong.......I am married and used to it:>) Here is link to the Tandy tutorial.
http://www.tandyleatherfactory.com/en-usd/Eco-Flo-Professional-Waterstains.aspx Hope this helps.
I will be fair and admit I never looked at the tutorial because I had done lots of dying before, and no one mentioned that I needed a different technique. Having read other posts about it I am a bit concerned about the durability of the colour. As well I tend dye very heavily so small nicks and scuffs will not show a difference in colour and I do not think I will get that level of coverage with this dye. I will admit it may not suck as badly as I initially thought, but based on these other reviews I am not convinced they are truly a viable option.
The Tandy Pro water stain works well, but you have to apply it like a thick rub on wood stain. Use a wet sponge and rub on a liberal coat and keep working it in. If you get a spot that is darker than the rest, take a clean wet sponge and wash it off lightly and blend with surrounding area. It does cover well, but there is a learning curve when you are used to pro oil dye. Gump
