Mike516 Posted January 16, 2014 Report Posted January 16, 2014 I posted this as a question in another existing thread but it's really not on topic there. So I decided to re-post it here...apologies for a double post but I can't remove the other one. I went to Harbor Freight and picked up one of their 1 ton presses. Mainly because I don't like the way my 3D stamps have been coming out on 3/4 oz leather. I ordered a 3/8 inch thick steel plate and am waiting for that to arrive. I have to get some wood clamps or something to secure it to my bench. And I'm trying to think what I should use to put on top of the steel plate - under the leather to get a nice crisp stamp. So I was wondering if anyone else uses regularly an Arbor press, and if so what kind of set-up you have. I could try trial and error but if I could get some help here I'm hoping to save myself some anxiety Quote
Tree Reaper Posted January 16, 2014 Report Posted January 16, 2014 (edited) 3-4 oz. isn't very heavy for stamping. Granite might have been a better choice than the steel for stamping but you can use nylon or poundo board on top of your steel plate. Edited January 16, 2014 by Tree Reaper Quote
Mike516 Posted January 16, 2014 Author Report Posted January 16, 2014 I think I wasn't clear. I use granite for stamping with a mallet. I'm referring here to an Arbor press (the title of the thread). Sorry for the confusion. Quote
Tree Reaper Posted January 16, 2014 Report Posted January 16, 2014 No confusion Mike. You can also use granite for stamping with an arbor press. You get smaller pieces cut to size, the problem is you have to buy a little larger press to accommodate the thickness of the granite but I don't know which press you purchased. Quote
Members mtroyalguy Posted January 16, 2014 Members Report Posted January 16, 2014 I was thinking of doing the same thing. When we get these arbor presses do we need to do anything to adapt them to accept the stamps? Quote
Members Dwight Posted January 16, 2014 Members Report Posted January 16, 2014 I have an arbor press that I also use for stamping letters, numbers, and designs. I took a piece of 1/2 inch plate steel, . . . placed it across the feet of my press, . . . and it is my bed for stamps, rivets, and when I get the right tool, . . . snaps. The only change I made, . . . I covered it with 2 inch wide masking tape to prevent any discoloration of the leather from the metal. Admittedly, . . . I don't do a lot with 3/4 leather, . . . but mine has come through for me in every case. As far as a "nice crisp stamp" goes, . . . the harder the plate under it, . . . the crisper the stamp, . . . but with 3/4 leather, . . . there is not enough thickness to get a really super looking stamp. AND, . . . forget the clamp idea, . . . bolt that thing down to your bench or whatever you want to use it on. Guaranteed, . . . if you don't, . . . it will move, . . . it will ruin a project, . . . and you WILL be unhappy. Temporary bolts with wing nuts will work if you only want to use it for a while, . . . but you are creating a huge force when you get your hand out on the end of that handle, . . . pulled all the way out, . . . Another thing you will want to do: adjust the handle so it is most comfortable for you to use. Are you left handed? If so, . . . take the collar off the left side of the gear shaft, . . . slide the shaft out the right side, . . . put it back in on the other side, . . . it makes a left handed press. Also, . . . put on your plate, . . . then block up the ram with a piece of wood simulating the length of your stamps, . . . and adjust the arm to be where it is most comfortable for you. I have mine just below horizontal, . . . it allows me to slip the handle onto my shoulder, . . . so I can reposition with both hands if I need to, . . . my shoulder holding the ram just up off the stamp. You adjust it by lowering it onto the block, . . . slide the gear arm out, . . . then slip it back in wherever it most comfortable for you. May God bless, Dwight Quote If you can breathe, . . . thank God. If you can read, . . . thank a teacher. If you are reading this in English, . . . thank a veteran. www.dwightsgunleather.com
Mike516 Posted January 16, 2014 Author Report Posted January 16, 2014 TR I said I bought a Harbor Freight 1 ton press. MT you take the plate with the slots off the base and replace it with a steel plate, unless you want to try granite as TR suggested. Quote
Members mtroyalguy Posted January 16, 2014 Members Report Posted January 16, 2014 It is that simple? Sweet. I think I will pick one up at Princess Auto next time I am in that part of town. Quote
Mike516 Posted January 16, 2014 Author Report Posted January 16, 2014 Good info Dwight. The tape especially is a very good idea. I was thinking if I used a thick piece of leather under the 3/4 oz it would help bring the image out. Quote
Mike516 Posted January 16, 2014 Author Report Posted January 16, 2014 It is that simple? Sweet. I think I will pick one up at Princess Auto next time I am in that part of town. I haven't used it yet, I'm still setting it up so don't take what I say as gospel. I hear some people don't like the small arbor presses and prefer heavier duty presses. Not sure yet but the 1 ton was cheap and I had a 20% off so I couldn't pass up the idea of trying it out. Not to mention it's at least another tool that I have now Never too many tools. Quote
